> New use for WD-40, Do not try this at home
914Sixer
post Jul 1 2008, 07:24 AM
Yesterday I was painting some parts that required that the paint be heated up to adhere properly. I was using a heat gun on the high setting (1200 degrees). The heat gun started to fall and like a FOOL I went to catch it. I the pain was INTENSE and immediate. I grabbed a can of WD-40 and soaked 3 fingers and the plam of my hand. My thinking was the old wives tale of putting butter on a burn. I was fully expecting to go to the emergency room to have my hand treated.
The WD-40 soaked in and started to relieve the pain. The pain came back a second time so I repeated the soaking. My hand required a third treatment. To my amazement I saw no blistering and the pain had subsided. The area was tender to the touch and red but that was all. I came inside to the house to clean up in case a trip to the doctor was in order but still no blistering.
The picture is of my hand this morning. The skin is tight on 3 fingers and my palm but you can not tell they were burned.
Ripley's believe it or not?
davep
post Jul 1 2008, 07:27 AM
914 Historian
Lucky sod. Good thinking, but I don't know why it worked.
Dr Evil
post Jul 1 2008, 07:54 AM
Send me your transmission!
Was it cool when you sprayed it? If you immediately apply cold to a burn (1* or 2*) you will slow down the reaction that causes the skin to blister, hurt, turn red. I would still expect it to slough off some if you killed any skin, but it will likely be less. If it wasnt due to the cooling effects of the WD40, then I dont know what happened.
Root_Werks
post Jul 1 2008, 08:00 AM
Village Idiot
I use WD40 and spray it on cutting blades and drill bits to keep them cool and sharp. Works great, especially when you don't have cutting oil handy. Maybe it does have a cooling property to it?
914Sixer
post Jul 1 2008, 08:12 AM
In response to Dr Evil, the WD-40 was not cool. It was about 80 degrees in the garage and I grabed it off the shelf. I am still baffled about the whole thing. My mother sent an email all about the uses of WD-40 but I thought it was urban legend stuff. Maybe there is some truth in it.
TeenerTim
post Jul 1 2008, 08:23 AM
Just be glad it was only a heat gun. My mother's uncle was cutting tree limbs with a chain saw when the same thing happened. (IMG:style_emoticons/default/new_shocked.gif) Needless to saw he lost his fingers.
swl
post Jul 1 2008, 08:51 AM
QUOTE(914Sixer @ Jul 1 2008, 06:12 AM) *
engage boy scientist mode:
When compressed gas (the propellant) expands it is cold - like a refrigerator. Even if the can was 80* the cooling effect of the expansion would make the spray quite cool. Couple that with the oils ability to transfer the heat away from your skin and Mikes theory seems reasonable.
boy scientist mode off:
There are some pretty stunning burn creams out there. My wife did the boiling oil trick to her thumb once and we had to take her to emerg. The stuff they put on was amazing but the dressing did not cover a small area at the margins. That which was covered never bothered her. The little strip that remained blistered and was really painful. Maybe the WD40 has some similar properties.
6freak
post Jul 1 2008, 08:56 AM
MR.C
QUOTE(914Sixer @ Jul 1 2008, 06:24 AM) *
Fish oils ..Its not listed on the label but its in there and it works for just such things ...... thats all i know
ConeDodger
post Jul 1 2008, 10:02 AM
Apex killer!
QUOTE(914Sixer @ Jul 1 2008, 07:12 AM) *
The WD40 was cool. At 80 degrees it was probably a 100 degrees cooler than the burning flesh. That bald kid should go to med school... (IMG:style_emoticons/default/biggrin.gif)
seanery
post Jul 1 2008, 10:46 AM
waiting to rebuild whitey!
thats pretty amazing!
MrKona
post Jul 1 2008, 10:56 AM
Great news to hear that your hand is doing so well...
But to preserve the scientific integrity of this experiment, we need a control group to see if WD40 worked better than immediate ice water would have.
Therefore, we need you to replicate the experience with your other hand and ice water immersion and let us know the results. (IMG:style_emoticons/default/biggrin.gif)
736conver
post Jul 1 2008, 10:59 AM
Fish oils
I remember my dad telling me about using wd-40 on burns. Never had to do it but always remembered.
dbgriffith75
post Jul 1 2008, 11:42 AM
TheGrif
I'll need to keep this in mind next time I'm playing with fire.... (IMG:style_emoticons/default/biggrin.gif)
Phoenix914
post Jul 1 2008, 01:26 PM
We should also have a volunteer try Windex. Or was I the only person who saw that movie?
PeeGreen 914
post Jul 1 2008, 02:37 PM
QUOTE(ConeDodger @ Jul 1 2008, 09:02 AM) *
I bet he'd make a good doctor someday if he did (IMG:style_emoticons/default/biggrin.gif)
Dr. Roger
post Jul 1 2008, 03:04 PM
A bat out of hell.
QUOTE(Phoenix914 @ Jul 1 2008, 12:26 PM) *
I was actually going to say that a friend suggested I try it and it worked. I was expecting it to sting like a Mo Fo but it immediately took the sting away. Totally surprised. She said it was the ammonia.
rufio0205
post Jul 1 2008, 03:24 PM
I was always told for minor to medium intense burns such as grabbing a glass pyrex dish straight out of the oven...for instance....skin to skin contact was best because it brings the temperature of your finger back down to normal body temperature...thus not shocking..thus not having a reaction such as a blister....could be myth...but in my simple experience 3 weeks ago...it worked well enough
plymouth37
post Jul 1 2008, 06:23 PM
Wow, I never thought of treating a burn like that. You see my solution is to yell out as many obsenities as possible as loud as I can, followed by kicking the s#!t out of what ever burned me, always worked for me!
swl
post Jul 1 2008, 07:38 PM
QUOTE(plymouth37 @ Jul 1 2008, 04:23 PM) *
(IMG:style_emoticons/default/av-943.gif)
The univeral cure all!
Pat Garvey
post Jul 1 2008, 07:40 PM
Do I or don't I...........?
QUOTE(plymouth37 @ Jul 1 2008, 06:23 PM) *
Reminds me of a scene from Deliverance.
The city boys catch a redneck pounding on a piece of steel - surprised him! Hits his hand with a hammer! He yells lots of nasty words & runs outside to kick the crap out of an old rusted Dodge.
They ask him if he's Ok - says it's Ok.
Great to have something to kick the crap out of, but I don't think my wife would feel the same, since her's is the only non-Porsche in the garage....and it's new.
- Lo-Fi Version Time is now: 18th July 2025 - 08:02 PM
