Rocker arm spacer use, with or without washers? |
bdstone914 |
Jul 2 2008, 11:16 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I was assembling the heads on a 2056 today and I purchased solid spacers from European motorworks. When I put the rockers together with the spacer replacing just the spring, while still having a washer on both sides, It will bind while going on, It just wont fit correctly, Without the spacers it fits with just a little wobble. So what should I do? Jake?
Jake Raby |
Jul 2 2008, 11:25 PM
Can't help ya.... Haven't used any other than ours for a long while now..
Back when I did use the EMW units they were steel and did not use the shims.. |
toon1 |
Jul 2 2008, 11:44 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
BOlt the rockers to the heads without the spacers and take a measurment of the inside dimention( the distance between the rockers where the spacer should be).
Then, measure the thickness of the spacers and washers. You want the spacer/washer stackup about .003 smaller than the distance between the between the rockers. When I did mine, I sanded the spacer until I got the right measurment. |
Lo-Fi Version | Time is now: 20th May 2024 - 04:00 AM |
