Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
hcdmueller |
Jul 6 2008, 05:04 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
New 96mm pistons and cylinders are available at Jake's store. You would have to reset the deck height and probably get new push rods. Add some new bearings, seals, and a few other odds and ends and you will be back in business. No need to get a 2.0 crank. If you upgrade to IDF or DRLA carbs you should get better performance too.
If you clean the heads up and post good pics of the combustion chamber Jake can usually spot cracks right away. It is actually kind of scary. |
Jake Raby |
Jul 6 2008, 06:02 PM
New 96mm pistons and cylinders are available at Jake's store. You would have to reset the deck height and probably get new push rods. Add some new bearings, seals, and a few other odds and ends and you will be back in business. No need to get a 2.0 crank. If you upgrade to IDF or DRLA carbs you should get better performance too. If you clean the heads up and post good pics of the combustion chamber Jake can usually spot cracks right away. It is actually kind of scary. Thanks Chris, We ship to Europe daily and have shipped Chris several items including an entire engine kit and FI retrofit assembly.. My video would have pinpointed EVERY fastener on the case during dis-assembly, one by one and each is counted. I can provide you with what's needed to just patch this engine up, no worries.. |
stephenaki |
Jul 6 2008, 10:50 PM
New 96mm pistons and cylinders are available at Jake's store. You would have to reset the deck height and probably get new push rods. Add some new bearings, seals, and a few other odds and ends and you will be back in business. No need to get a 2.0 crank. If you upgrade to IDF or DRLA carbs you should get better performance too. If you clean the heads up and post good pics of the combustion chamber Jake can usually spot cracks right away. It is actually kind of scary. Thanks Chris, We ship to Europe daily and have shipped Chris several items including an entire engine kit and FI retrofit assembly.. My video would have pinpointed EVERY fastener on the case during dis-assembly, one by one and each is counted. I can provide you with what's needed to just patch this engine up, no worries.. Chris, Jake, So if I stick to 94s instead of going to 96s I assume that I don't have to reset the deck height and can stick with the same pushrods? I planned on getting new bearings regardless but will stick with the Dellorto carbs I have now. I set everything up and kept them in order labeling each part so I know where it goes back to with the exception of the case bolts. What about the distributor gear, salvageable with cleaning up or toss and get a new one? I know that this is the cheap way out but I just need her running before it gets cold this season. I don't want to have to ride my motorcycle in the snow again! (IMG:style_emoticons/default/screwy.gif) Thanks for all the help. |
rick 918-S |
Jul 7 2008, 07:10 PM
Hey nice rack! -Celette Group: Members Posts: 20,417 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
New 96mm pistons and cylinders are available at Jake's store. You would have to reset the deck height and probably get new push rods. Add some new bearings, seals, and a few other odds and ends and you will be back in business. No need to get a 2.0 crank. If you upgrade to IDF or DRLA carbs you should get better performance too. If you clean the heads up and post good pics of the combustion chamber Jake can usually spot cracks right away. It is actually kind of scary. Thanks Chris, We ship to Europe daily and have shipped Chris several items including an entire engine kit and FI retrofit assembly.. My video would have pinpointed EVERY fastener on the case during dis-assembly, one by one and each is counted. I can provide you with what's needed to just patch this engine up, no worries.. Chris, Jake, So if I stick to 94s instead of going to 96s I assume that I don't have to reset the deck height and can stick with the same pushrods? I planned on getting new bearings regardless but will stick with the Dellorto carbs I have now. I set everything up and kept them in order labeling each part so I know where it goes back to with the exception of the case bolts. What about the distributor gear, salvageable with cleaning up or toss and get a new one? I know that this is the cheap way out but I just need her running before it gets cold this season. I don't want to have to ride my motorcycle in the snow again! (IMG:style_emoticons/default/screwy.gif) Thanks for all the help. Someone will answer your questions soon. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/popcorn[1].gif) List the parts you need. I'm sure I don't have much but there are alot of guys here that do. |
stephenaki |
Jul 8 2008, 01:06 AM
QUOTE Someone will answer your questions soon. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/popcorn[1].gif) List the parts you need. I'm sure I don't have much but there are alot of guys here that do. OK, in order to do the proper conversion that Jake outlines I am in need of the following items. 2.0 Crank 2.0 connecting rods I found a set of AA 94mm piston cylinder set so all I need to fully convert this sucker is the crank and connecting rods. If anyone has them please let me know and how much with shipping of course. I would rather do a proper conversion than just a half assed job. The remaining items, bearings etc, I can get easy once I do the requisite measurements on the crank, etc. I'll be standing by for any assistance you all can give me. (IMG:style_emoticons/default/beerchug.gif) |
Smitty911 |
Jul 8 2008, 09:58 PM
Member Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California |
QUOTE Someone will answer your questions soon. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/popcorn[1].gif) List the parts you need. I'm sure I don't have much but there are alot of guys here that do. OK, in order to do the proper conversion that Jake outlines I am in need of the following items. 2.0 Crank 2.0 connecting rods I found a set of AA 94mm piston cylinder set so all I need to fully convert this sucker is the crank and connecting rods. If anyone has them please let me know and how much with shipping of course. I would rather do a proper conversion than just a half assed job. The remaining items, bearings etc, I can get easy once I do the requisite measurements on the crank, etc. I'll be standing by for any assistance you all can give me. (IMG:style_emoticons/default/beerchug.gif) http://dprmachine.com/Html%20Files/cranks_type_4a.htm Here is a place in Santa Ana that has 2.0 cranks and connecting rods. There about 10 miles away from me. Smitty |
stephenaki |
Jul 9 2008, 01:00 AM
http://dprmachine.com/Html%20Files/cranks_type_4a.htm Here is a place in Santa Ana that has 2.0 cranks and connecting rods. There about 10 miles away from me. Smitty Thanks, pretty reasonable price for the stock stuff, any experience with them at all? |
Lo-Fi Version | Time is now: 24th April 2024 - 12:42 AM |
