Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Dec 15 2008, 07:09 AM
OK, I think my car has a curse on it or something to that effect. (IMG:style_emoticons/default/huh.gif) I called Christoph this morning, bearings are in...WOOHOO! He wants me to bring a connecting rod with me so we can test fit the rod bearings as well, no problem. Take off at ten, swing by the house, pick up the connecting rod and wife and off we go.
Get to Dotternhausen and walk into the shop; for those that are interested, his website is www.boxmot.de, ist nur auf Deutsch. Christoph pulls out the crank bearings and we slide them on...perfect! He yells for Udo to undo the nuts on the connecting rod then wanders off while Udo takes a rod bearing and puts it in...ok, tries to put it in. NOPE (IMG:style_emoticons/default/headbang.gif) So he measures the inside of the connecting rod assembled, 52, measures the bearings put together 55. Holy shiessa! Thats waaaaaaaaaay off! Well the next 30 minutes are spent trying to figure out what happened but when it is all said and done the crank and connecting rod are at Christoph's place so he can make sure the next set of bearings are the right fit. Damnit, so close!. On a positive note, I borrowed a metric tap and die set from the autocraft shop and cleaned up all the holes and studs. Need to finish cleaning the left half of the case and then will stick it into a platic bag to keep the dust off of it. Had the boy clean all the studs before I put them back on and had him cleaning the impeller as well. I had hoped that I could have the engine reassembled before the 24th but that I think is now out the window. Good thing my wife is understanding, for that matter good thing I am otherwise Christoph would have gotten an ear full. Oh well, stuff happens, no sense getting too worked up about it cause it won't change it. Stay tuned for more misadventures of the 914 chronicles (IMG:style_emoticons/default/screwy.gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 10:50 AM |
