Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Sep 28 2009, 01:10 PM
So, I was able to get a floor jack and some stands from the autocraft shop as a loaner; I was asked why I didn't just bring the car to the shop and do it and I pointed out that I would wind up tying up one of his bays for several days and didn't want to do that. "OK" he says and off he goes in search of jack stands while I go and find a floor jack.
I had hoped to start on Saturday or Sunday but didn't get the chance until this afternoon. I got everything disconnected using the tutorial on the PP tech page. Very well written and easy to follow, you just have to make modifications based on the year of your car and some other things like carbs vs FI and heat exchangers. I thought it would be more complicated but once I began the process I found it very simple. At least until it was time to disconnect the CV joints. Checked my tools, I don't have the needed 8mm 12pt hex head CV bolt removal tool. OK, shoot off to Toom (think German style home depot) which is down the street. They have one but you have to buy an expensive, about $60, tool set to get the specific piece. Well, I don't need all the other crap and they don't have the particular item as a 12pt set either. So, I'm dead in the water until tomorrow. I will check at the autocraft shop to see if they have the tools I need and borrow it. I am hoping I can finish the motor drop tomorrow and start working on changing out the seals while the weather still holds here in Deutschland. If the autocraft shop doesn't have the tool there are a couple of other possibilities in Boeblingen that I can check out. Wish me luck! |
Lo-Fi Version | Time is now: 24th April 2024 - 03:59 PM |
