Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Oct 15 2009, 11:51 AM
So, I've evidently I have bronchitis, great. Needless to say they tell me to go home and stay home. I can do that. Now, being the stubborn SOB and since I receive a lot of help getting the valves done and the car is running....time to synch the carbs!
First off, my damn archaic SU Carbs are easier to synch than these Delortos; not because they are complicated but because it is awkward to get to the fast idle screw. So the car is running, so far no oil, I'm screwing around with the damn carbs, kinda smokey in here (IMG:style_emoticons/default/blink.gif) must be that damn exhaust leak. Well, the passenger side carb is being a pain cause the screw is on the inside and I have to lean over the engine bay and do the contortionist thing to get to the screw. Well, need to take a break for a minute, lets see if I got any oil leaks....can you see where this is going?? HOLY SHIT! I got me a pool and it's under the number two cylinder! GODDAMNIT!!! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) So, I turn off the car, jack it up, clean up the pool of oil and crawl under there with a flashlight. Definitely not from the push rod tubes, those are good, nothing pooling on the bottom of the impeller fan housing, nothing on the rear main (at least that is fixed). What the hell? There are droplets on the engine mount and the tin right below the number 2 cylinder. Hmm, is it possible that their is a leak between the head and the #2 cylinder? Well, looks like I'll be dropping the motor...again. So any suggestions on what I should be looking for? I can see the seam between the crankcase and the cylinders but I don't see any oil there. I am pretty sure it is from the cylinder and head; I didn't 'lap' the head but used a gasket. I will take a break tomorrow, doctors orders, then look at dropping the motor on Saturday. If anyone has any words of wisdom it would be appreciated. Just when I think I finally got things licked. I guess it's a good thing i'm a stubborn asshole, otherwise this car would have been at the bottom of a lake somewhere. |
Lo-Fi Version | Time is now: 29th March 2024 - 12:12 AM |
