Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Jan 12 2010, 01:15 AM
So, it's been snowing here since last Friday and only stops to take a breather. We have at least 18 inches if not more and I have been driving the teener, now heat, windows cracked so the windshield doesn't fog up.
As mentioned earlier, the sucker wsa running fast because the cable was not quite right. I adjusted it the other day but it seems as if the pedal wasn't returning all the way back up; it was just shy about a mm or two. Anyway, I drive to work today, when you get off the autobahn to go to Patch Barracks the exit has a light at the end, if you turn right you head downtown to Vaihingen. If you turn left, you head to Patch and a turn off onto Pascal strasse that takes you to Boeblingen; right in front of you is a big Audi and VW dealership. As I slow and stop, the car is idling high again. OK, put it in neutral, engage the E-brake, now, reach down pull the gas pedal back a bit and voila! Idle goes down. Clearly I need to see what is going on there. Light turns green and we creep up some more until there is only one car in front of me when the light turns red again. So, lets do the same thing...OOOOOPS! I pulled just a bit too hard and the pedal popped loose! (IMG:style_emoticons/default/headbang.gif) Well, this isn't good (IMG:style_emoticons/default/blink.gif) OK, don't panic, try to put the pedal where it belongs and when the light turns green, pull straight into the car dealership to figure out what the hell just happened. Well, I got her there, barely and cut the motor. I had my flashlight with me because I had to re-install the damn rear view mirror again this morning so I took a look down there. Well whatdya know, the pedal is a ball joint style set up; I would know this if I had done more work down there. At least thats a releive, it souldn't be too hard to fix. Well after a couple of tries, I got it lined up properly, pushed all the way down till it stopped moving and slapped the shit out of of it to make it go back into the socket! (IMG:style_emoticons/default/smash.gif) It worked! (IMG:style_emoticons/default/cheer.gif) So, start her back up and head to work. Hmm, the idle seems to have resolved itself as well (IMG:style_emoticons/default/idea.gif) Wonder if she just needed a mild beating? We will see if it truly resolved itself when I head home today. Just thought I would share yet another misadventure of the yellow bomber (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 09:26 AM |
