Steve's unending Progress thread, Air compressor setup recommendations |
stephenaki |
Jul 5 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, this will be the thread that I keep updated as I make progress. I showed up at 0800 at Christoph's place and he was ready for me with a not so glamorous chunk of metal that is my cars heart and soul.
With a little assistance, we loaded it into my Toyota Sienna, not quite I envisioned a mini-van for, and I was headed back to the house. Upon getting home I had to first make coffee then clear out some space in my tiny German garage. So that everyone has a frame of reference to the area that I am working in I have enclosed this lovely 4x6 glossy of my garage in Germany. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747638.1.jpg) And, for those of you not familiar with the Toyota Sienna, a shot of the engine in the back of the van. There's a lot of room back there for the motor but, it is awkward to get in and out of when loading a motor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.2.jpg) Now to summarize what was accomplished on the 4th of July, engine brought home, tin, impeller and housing, exhaust, cylinder head and cylinders removed. I had difficulty removing the impeller hub. OK, I didn't get it removed, will need a puller and I don't have one unless anyone can give me any ideas how to get it off without a puller. Now for the requisite pictures of the motor unmolested. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747639.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747640.4.jpg) Now based on the initial tear down two problems presented it self first the primary issue with a lack of compression...HOLY SHIT!!! Here is what I found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747641.5.jpg) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Now the cylnder itself was not pitted, it had a build up of corrosion but otherwise in good condition. So I was thinking, maybe I can just clean hone and replace the piston. Well that thought went out the window when I pulled the cylinder directly opposite to it. As you can see by the photo, problem #2. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.6.jpg) More importantly, where did that piece of metal go? An initial look behind the piston shows a knick in the inner portion of the crankcase. (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-7987-1268747642.7.jpg) I will see if there is more significant damage when I split the case; so it begins and were off to a rocket start here at the 914 follies! Stay tuned for the next exciting episode of "never buy a car sight unseen" later in the week! (IMG:style_emoticons/default/happy11.gif) Gonna go shower and start working on the motor some more. Plan is to have it completely torn down befor the end of this weekend. I will load up some pictures to my photo bucket album and post the link a bit later. |
stephenaki |
Jan 23 2010, 04:20 AM
OK, phase 2 in this money pit and I need some help from the experts on this forum.
First, cylinder heads. I have a 1.7 machined for a 2.0; how much benefit would I get if I actually throw in 2.0 heads? What else will I have to change i.e. exhaust system etc. Transmission. I want to convert to a side shifter, if I can find a 73-75 year tranny what else will I need to do to fit it? Finally, fuel injection. Which is recommended regardless of 1.7 or 2.0 heads? I think the first project will be the tranny conversion then I will make a determination of what to tackle next depending on feedback to my other two questions. |
ChrisFoley |
Jan 23 2010, 05:58 AM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have a 1.7 machined for a 2.0; how much benefit would I get if I actually throw in 2.0 heads? What else will I have to change i.e. exhaust system etc. What do you mean "machined for a 2.0"? Be more specific. If the displacement is still 1.7 and the cam is near stock, stick with the 1.7 heads. QUOTE I want to convert to a side shifter, if I can find a 73-75 year tranny what else will I need to do to fit it? You need the later engine support crossbar along with the later center and outer mounts. You need the complete shift linkage and shift lever. You need a firewall bushing made for the conversion, since the rod diameters are different in that location. QUOTE Finally, fuel injection. Which is recommended regardless of 1.7 or 2.0 heads? If you have 2.0 heads you need to use the 2.0 FI runners since the bolt pattern is different. Then you also need the 2.0 plenum because the runners are larger diameter. Etc. If the displacement is only 1.7 don't change the heads, and stick with 1.7 injection. If the displacement is 1.9 or more, switch to the 2.0 heads and go with the 2.0 injection. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:42 PM |
