914 brake question |
honlude |
Jul 13 2008, 03:31 PM
Newbie Group: Members Posts: 23 Joined: 21-January 08 From: York Pa Member No.: 8,603 Region Association: MidAtlantic Region |
Hello
i am working on my 1975 914 1.8 , i rebuilt the master cyl , rebuilt right rear caliper , and replaced left rear caliper , replace the grommets on master cyl for resov. lines , i have set the rear brake venting to .008 and bleed the system multiple time , i have no air coming thru system at all , i have brakes now but they just dont seem to be correct , if i stand on the brakes hard they do not lock up while driving, are the brakes on these just that way or dose anyone have any other suggestions on what could be a problem , ... i have no leaks anywhere either and the park brake seems to hold the car under a light load thanks craig |
ClayPerrine |
Jul 13 2008, 08:46 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hello i am working on my 1975 914 1.8 , i rebuilt the master cyl , rebuilt right rear caliper , and replaced left rear caliper , replace the grommets on master cyl for resov. lines , i have set the rear brake venting to .008 and bleed the system multiple time , i have no air coming thru system at all , i have brakes now but they just dont seem to be correct , if i stand on the brakes hard they do not lock up while driving, are the brakes on these just that way or dose anyone have any other suggestions on what could be a problem , ... i have no leaks anywhere either and the park brake seems to hold the car under a light load thanks craig You used the wrong venting clearance. There is a typo in the Haynes manual. The actual venting clearance is supposed to be .004. And you also have to bleed the proportioning valve. The brakes won't work correctly if you don't get all the air out of the prop valve. I personally dislike them, and replace them with a T fitting. The brakes feel better with less pedal travel if you do. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:34 AM |
