Need Help Removing Steering Rack, Now I Get IT!!! |
ericread |
Aug 2 2008, 05:13 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
HELP!!! I have read and re-read the prior posts on steering rack replacement. I am at the point where the following has been completed:
1. Removed fuel tank. 2. Removed right and left tie rods. 3. Detatched U-Joint directly inside driver compartment. 4. Removed two bolts that attach steering rack to the support. 5. Removed two bolts that attach support bar to body (off the tabs that face the rear of the car (shown at item 6 in the diagram). 6. Removed the two bolts that attach master cylinder to the bulkhead/pedal cluster. 7. Removed the two bolts that hold the steering shaft bearing (over the steering shaft bellows underneath the fuel tank). Question 1: How do I move the master cylinder out of the way? The short brake line that goes to the tunnel doesn't give the master cylinder a lot of distance to back off, and the support bar (item #1 in the diagram) is in the way when I pull the master cylinder back. Question 2: How do I actually remove the rack? The steering shaft directly connected to the rack seems to require that I drop the rack directly down. But the bolt tabs on the support bar itself (Item #1 in the diagram), as well as the bolt tabs that run a few inches to the underside of the body (towards the rear or the body) (item # 6 in the diagram) all seem to be in the way? What am I missing??? My thanks. Eric Read |
Spoke |
Aug 2 2008, 09:27 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Just looked at your pics. Your jackstands are under the crossmember so you will have to reposition them behind the front wheel wells where are the little bumps. Use a piece of wood to distribute the weight and place near the edge of the wheel well so the weight isn't on an unsupported area of the floor pan.
Attached image(s) |
ericread |
Aug 2 2008, 09:39 PM
Just looked at your pics. Your jackstands are under the crossmember so you will have to reposition them behind the front wheel wells where are the little bumps. Use a piece of wood to distribute the weight and place near the edge of the wheel well so the weight isn't on an unsupported area of the floor pan. Take a close look and you'll see the top of the jacks are actually several inches under the crossmember. My primary jackstands are under the lifting "bumps" you mention. These are secondary jackstands in case I experience a failure with a primary jackstand. I will move them aside when I drop the crossmember. Thanks for taking a look at the pics. Let me know if you see something else that might pose a problem. Your review and advice is greatly appreciated. Eric (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:40 AM |
