Intake plenum size 2.0 vs 1.7?, What is the diference? |
Joe Owensby |
Aug 7 2008, 10:24 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I have a 2056, that I am planning to go back to FI from carbs. I have looked at several of the after market complete systems, but I think I would like to maybe have a stock type air plenum and intake runners. This would be with a new throttle switch, pressure and temp sensors, etc. , and then either a SDS or microsquirt controller. I am thinking more of overall day to day drivability, summer and winter, as well as fuel economy. I am thinking that the single plenum arrangement will be simpler to adjust and maintain than the dual throttle bodies. I am also thinking that it will be a little quiter. I now have the dual carb set up, and it sounds good if I am tooling around on country roads, but is annoying if I am cruising down the highway wanting to listen to the radio. I guess I am gettinng old.
If so, would I need to upgrade from a 1.7 D jet system to a 2.0 system? I have the old 1.7 system components from my engine. I was thinking that I should get a 2.0 plenum and intake runer system, then add new throtle switch, and other sensors, including 02, etc. I noticed the recent post on the microsquirt system which looked interesting. I am also not trying to start a debate on the merits of the different controllers now, just asking about the air management system. Are the filters, etc. for these still available? Thanks for any advice. JoeO |
type47 |
Aug 7 2008, 10:39 PM
i don't have experience in your plans but i would think you would need a 2L d-jet intake and filters for the 2.0L intake are readily available. also would think finding used would be easy. now, instead of getting a new MPS, why not go SDS or microsquirt now instead of later. do you now have 2L heads (3 bolt) on the motor?
Aug 7 2008, 11:20 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A bunch of differences. The 2.0 intake runner pipes are shorter and wider diameter than the 1.7 ones. The 2.0 plenum is wider (that's why the 2.0 pipes are shorter), has a larger volume, and has the throttle body sitting on top of it instead of sitting on the side. The 2.0 TB is larger than the 1.7 one as well.
--DD |
sean_v8_914 |
Aug 8 2008, 10:06 AM
XCGV
sean_v8_914 |
Aug 8 2008, 10:08 AM
...AND THE 1.7.
Bleyseng |
Aug 8 2008, 08:38 PM
2.0L set up for a 2056.
Attached thumbnail(s) |
Joe Owensby |
Aug 10 2008, 06:36 PM
thanks for all the detailed info and photos. Yes, I am thinking of using either SDS, or Microsquirt, with a new throttle switch, pressure sensor, etc. The heads I have are from one of Jake's kits. They have the 4 bolts. I assume one can just drill the center hole and use a 2.0 intake on these? If so, I will post on the classified ad secton for the intake, air cleaner box, and hardware. Is there anything else I should get?
thanks again, JoeO |
Bleyseng |
Aug 10 2008, 08:26 PM
Have Jake order them with the 3 bolt option as its welded in and then drilled.
Are you going to order them with the relocated sparkplug location? Adds about 5-10 hp. |
davep |
Aug 10 2008, 09:30 PM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I recall someone saying that the 1.7 plenum flows better than the 2.0 due to its shape. Unless you are going for extreme HP (if you did, you probably don't want a plenum) then the flow characteristics of the runners would likely make no difference. Considering that, I'd be inclined to stay with the 1.7 parts you already have.
Bleyseng |
Aug 11 2008, 12:31 AM
Jake Raby has said the BUS plenum with 914 2.0L runners flows better than the 914 2.0L plenum setup on a dyno. Ok, maybe so but its gonna take some work to make it work so the stock 2.0L 914 setup is the easy way to set up FI.
now if you are going with MS, SDS or ? then maybe its just as easy to set it up like Jake. No way is the 1.7L setup as good as the 2.0l stuff as its much smaller reducing air flow. |
james2 |
Nov 30 2008, 06:14 PM
Member Group: Members Posts: 97 Joined: 28-June 08 From: Georgia Member No.: 9,225 Region Association: None |
Jake Raby |
Nov 30 2008, 06:35 PM
What the 914 2.0 plenum gains in size, it loses in design. This is when tested on my engine combinations, so it can't be generally applied as a blanket statement for all engines/cams/heads.
Joe's engine would benefit from a 2.0 Bus Spec plenum since that combo likes velocity more than gross flow. The 2.0 Bus is the largest horizontal charged plenum and it's internals make for much better interal air delivery to all 4 cylinders. The 2.0/914 plenum favors the #2 and #4 cylinders more than 1&3 and this is notable with EGT data logging and head temps as well. As always- Design trumps size. Smarter. Not Larger. That always defys conventional wisdom concerning "Hot-rodding" and confuses lots of people. I have used a 2.0 Bus plenum on an engine of 2615cc making north of 200HP at only 5,500 RPM. |
type47 |
Nov 30 2008, 06:43 PM
i would wonder how similar the "bus plenum" and the 914 L-jet plenum are...... buses were L-jet.
james2 |
Nov 30 2008, 06:49 PM
Jake, I have a EFI system looks like the one installed in this picture, air filter mounts on top , not over to the side. side draft throttle body? What is it off of? picture hotlinked from above.
(IMG:http://www.914world.com/bbs2/uploads/post-3541-1218211493.jpg) |
Jake Raby |
Nov 30 2008, 07:03 PM
James,
The plenum on the left is a 2.0/914. Its the only unit that has a vertical throttle body placement. The other plenum is cluttered too much to absiolutely ID it, but it does look a 1.8/ 914 or 2.0 Bus unit based on what I can see in the pic. |
james2 |
Nov 30 2008, 07:06 PM
Thanks. (IMG:style_emoticons/default/biggrin.gif) James, The plenum on the left is a 2.0/914. Its the only unit that has a vertical throttle body placement. The other plenum is cluttered too much to absiolutely ID it, but it does look a 1.8/ 914 or 2.0 Bus unit based on what I can see in the pic. |
Jake Raby |
Nov 30 2008, 07:09 PM
Hey James, if you want to make a trip to the mountains I could use a hand in the new shop.... I added another 3,500 square feet and it's two stories high :-) (and we now have a chassis dyno!)
james2 |
Nov 30 2008, 07:12 PM
Wow, it would be nice, call me Monday.
Lo-Fi Version | Time is now: 11th May 2024 - 04:37 AM |
