jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,809 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
There is a support to the rocker panel top just in front of the trailing arm. Mine has broken away. It's a tricky area to get to anyway, has anyone done this repair ?
There was a screw holding the strap to the rocker edge, but the hole gave way and there is little to grab onto. |
roadster fan |
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California ![]() |
I havent done the repair but I have removed mine while I install GT flares. It is welded from the factory, but I guess if you dont/cant weld it you could use a rivet or two for a semi-permanent repair.
You say there isnt much to grab onto, so welding is probably best. Jim Oh, and before someone else says it (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
jim_hoyland |
I'll shoot a pic--it's such a tight spot, I don't think it will show much.
I havent done the repair but I have removed mine while I install GT flares. It is welded from the factory, but I guess if you dont/cant weld it you could use a rivet or two for a semi-permanent repair. You say there isnt much to grab onto, so welding is probably best. Jim Oh, and before someone else says it (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Lo-Fi Version | Time is now: 8th July 2025 - 10:57 AM |
