5 lug Conversion, What would you do? |
jesiv |
Aug 24 2008, 01:04 AM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Ok I am starting to play. So I purchased the complete suspension from a drilled 5 lug conversion (complete front including rack and rear trailing arms with drilled 5 lug hub). My plan was to buy a sway bar, tubro tie rods, koni adjustable and then replace entire front suspension. I thought I was clear on what I was going to do.
Today I found a great deal on a freshly rebuilt 72 911 front suspension with 911 sway bar and torsion bars. It is a complete suspension minus steering rack and tie rods. So I am thinking I should install the 911 stuff. Or should I mix and match parts. (IMG:style_emoticons/default/dry.gif) The 911 brakes sure look nice (IMG:style_emoticons/default/piratenanner.gif) Also would you get 15 or 16 fuchs? (IMG:style_emoticons/default/WTF.gif) Regards, James |
PeeGreen 914 |
Aug 24 2008, 01:08 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I have the front end from a '78 SC with a 914 style sway bar. My struts are the 3 1/2 spacing for the calipers though. I run 15s. I really like how my front feels.
Eric_Shea |
Aug 24 2008, 01:32 AM
"Totally" depends on what you want to do with your car.
You can't go wrong with the 72 911 struts. You may simple want to add them to your a-arms for the best ride quality. While Jon likes how his front end feels, he may be using them for different over purposes than you or most. (IMG:style_emoticons/default/wink.gif) |
PeeGreen 914 |
Aug 24 2008, 02:03 AM
NO. Everyone must be doing the same thing as me (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/laugh.gif)
Okay, I guess I should add that my car has been set up for short trips and AX. I drive to all the events which is about 60 to 80 miles each way. This car is NOT a daily driver. It could be if I went to my chiropracter every day |
jcd914 |
Aug 24 2008, 02:40 AM
I voted "Use existing front end replace with 911 strut/hub with 914 Koni Shocks, turbo tie-rods, 914 sway bar"
I had already set up my suspension for auto-x with Yellow Koni gas sport shocks frt & rr, a thru body 19mm adjustable sway bar, 21mm or 22mm T-bars, poly bushings frt & rr. When I went to 5 lug I used 72 911 struts, hubs and brakes, 4cyl rear hubs drilled for 5 lug with 6cyl rotors and 4cyl calipers. On the frt; I pulled my frt struts out swapped the Koni's to the 911 struts and back together with. On the rear I swapped the hubs and 914/6 rotor for what I had and when back together with it. I would guess I rechecked my corner weights and alignment but it has been too long to remember for sure. I will note that early 911's and 914's used the same type of sway bars. Thru the body under the fuel tank on a 914 and behind the fuel tank on a 911. Latter (74 I think) 911's used and under body sway bar. I prefer the thru body bars because there are aftermarket adjustable bars available so you can better tune the suspension. I used mine for auto-x and daily driving. I was a bit stiff and harsh but I did not mind. Jim |
marks914 |
Aug 24 2008, 08:44 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I decided to run 82 911 SC struts, hubs, brakes, ball joints with turbo tie rods and a 914 19mm sway bar. I had a ste of 15" phone dials, but now I have some 17" boxter S alloys
Mark Rides nice, even on Michigan roads, which have to be the worst roads in the country. (IMG:http://inlinethumb42.webshots.com/41449/1236147744057582025S500x500Q85.jpg) (IMG:http://inlinethumb35.webshots.com/30306/1236147814057582025S500x500Q85.jpg) (IMG:http://inlinethumb13.webshots.com/40332/1253350713057582025S500x500Q85.jpg) |
ConeDodger |
Aug 24 2008, 10:14 AM
Apex killer! Group: Members Posts: 23,581 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I went with my original 4 cylinder front end but replaced the hub and rotor with a crossdrilled SC rotor and a billet hub available in the Classifieds here. Very nice product. Brake calipers can be M calipers from the early 911 but I am going to try something different. You can see them peaking out from behind that Fuch. Aluminum mmmmmm..... (IMG:style_emoticons/default/biggrin.gif)
In the rear, I went with PMB rebuilt and modified trailing arms. You can't get easier than that. Wheels are 16X6 Fuchs.. Attached thumbnail(s) |
McMark |
Aug 24 2008, 09:42 PM
I'm working on this as well. I have early 911 Boge 3" struts that'll get non-vented/solid rotors and use my existing calipers. This way I can install the struts in an afternoon without having to rebleed my brakes. Later I will bolt on vented rotors and stock rebuilt caliper with spacers.
Minimum work: replace struts Maximum work: replace entire front suspension Difference at the end of the day: full 911 setup has better torsion bar selection. I'll stick with the 'measly' 914 torsion bar selection and go for minimum work. (IMG:style_emoticons/default/cool.gif) |
jesiv |
Aug 24 2008, 10:24 PM
I see where y'all are coming from. One thing that just occurred to me is that my a-arms do not have utabs (which got me looking at front suspensions to begin with) so I have to replace a-arms.
So seems link complete 911 front suspension is the best and equal effort route? Opinions... Thanks for the real life opinions. Regards, james |
Eric_Shea |
Aug 24 2008, 10:26 PM
QUOTE I'm working on this as well. I have early 911 Boge 3" struts that'll get non-vented/solid rotors and use my existing calipers. This way I can install the struts in an afternoon without having to rebleed my brakes. Later I will bolt on vented rotors and stock rebuilt caliper with spacers. It will work with the solid rotors if you have early 914 calipers, not late (unless by existing calipers you mean existing M-Calipers that came with the early front end; see below). Also, you will have to change hubs when you add the vented rotors. The vented rotor hub has a 3-4mm face set difference from the solid rotor hub to make up for 1/2 the distance of the new spacers. What do you mean by stock rebuilt caliper with spacers? 911 M-Caliper? Personally, I like the 914 torsion bars for... well... the 914. Especially a car that will be spending 80-90% of it's time on the street. |
GeorgeRud |
Aug 24 2008, 10:29 PM
The U-tabs can be added to any arms, so that's not a problem. I replaced the struts on my car with early 80s Carrera struts and brakes, but I'd just look around and see what you can find with a good price. These parts are all pretty much interchangeable, and there is no real advantage to -4 or -6 arms other than the number of splines on the torsion bars. The same with the crossmember, the aluminum one is not that much different than the early steel ones.
jmill |
Utabs?. Are you talking about the swaybar to a-arm attachment? You can buy those and just weld them on.
McMark |
Aug 24 2008, 11:26 PM
But if you've already got 911 arms with suitable tabs, then run those. Welding vs. just swapping.
QUOTE What do you mean by stock rebuilt caliper with spacers? Front calipers with spacers in between the halfs... Crap, I thought this was going to be easy... (IMG:style_emoticons/default/dry.gif) |
Eric_Shea |
Aug 25 2008, 07:35 AM
QUOTE Front calipers with spacers in between the halfs... I guess the question is "what" front calipers. The previous comment in your post make it sounds like you'd be using stock 914 front calipers. QUOTE I have early 911 Boge 3" struts that'll get non-vented/solid rotors and use my existing calipers What I'm trying to say is: 1. You could do that (use 914 calipers on an early 911 front end) but, they would have to be the early 1970-1972.5 variety. 2. If you're talking M-Calipers it would be best to get the ones with the spacers and build those in advance. You could then put them together without the spacers but with the longer fasteners. This way, when you wanted to add vented, simply install the spacers. 3. Your main problem in this would be the hub. I've had the two side by side. The geometry escapes me now but I "think" the later hub has 3-4mm "added" to the rotor mounting sufrace so... no, this won't be easy. |
McMark |
Aug 25 2008, 11:23 AM
I was thinking stock calipers the whole time.
I have the solid rotor hubs and 'some other' hubs. I'll get all the parts back to the shop and do some comparison. (IMG:style_emoticons/default/hijacked.gif) (IMG:style_emoticons/default/hijacked.gif) (IMG:style_emoticons/default/hijacked.gif) |
McMark |
Aug 25 2008, 12:12 PM
You're 100% correct Eric! (of course)
I'll have to run the solid rotor hubs as well. I think I'd better test fit all of this before I go to put it on the car. |
Aug 25 2008, 01:01 PM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I went and got a complete 911 frontend from a '84 Carrera ...
Crossmember, A-Arms, Underbody Swaybar, Struts & Shocks, Hubs, Rotors, Calipers ... The whole Shebang complete and together, direct bolt-in. No need to worry about mis-matching parts plus you get the 3.5" caliper spacing which makes for easier brake upgrades down the road. I ran with the 911 underbody swaybar for a few weeks and they work great. I went to a through body bar later for adjustability, but for a street car, the underbody bar works just fine. I also like the slightly heavier torsion bars on the 911 A-Arms. (IMG:style_emoticons/default/shades.gif) Andy |
jesiv |
Aug 25 2008, 09:08 PM
Ok, so based on your experience, if I install 911 suspension... Will 15x6 or 16x6 fuchs just fit... No Problems? (IMG:style_emoticons/default/dry.gif)
Regards, James |
McMark |
Aug 25 2008, 09:15 PM
Any 'Porsche' wheels will fit with two caveats: wheel spacers and fender flares. You are now entering the world of Wheel Offsets
Todd Enlund |
Aug 25 2008, 09:26 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
You are now entering the world of Wheel Offsets AAAAAHHHHhhh! (IMG:style_emoticons/default/yikes.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 02:28 AM |
