5 lug Conversion, What would you do? |
PeeGreen 914 |
Aug 25 2008, 09:34 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Ok, so based on your experience, if I install 911 suspension... Will 15x6 or 16x6 fuchs just fit... No Problems? (IMG:style_emoticons/default/dry.gif) Regards, James The 911 suspension wouldn't make it any different for what wheels you can use other than the whole 5 lug thing. Yes, 15 or 16x6s would easily fit on any stock/nonflaired 914. |
Aug 25 2008, 09:58 PM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The 911 suspension wouldn't make it any different for what wheels you can use other than the whole 5 lug thing. Not true. The Carrera Hubs will put the wheel mounting surface further out ... (IMG:style_emoticons/default/bye1.gif) Andy |
PeeGreen 914 |
Aug 25 2008, 10:00 PM
(IMG:style_emoticons/default/confused24.gif) I've never seen a problem with 15x6s though. The only ones I have seen any issue with are 7s. He was asking about Fuchs right?
Aug 25 2008, 10:19 PM
(IMG:style_emoticons/default/confused24.gif) I've never seen a problem with 15x6s though. The only ones I have seen any issue with are 7s. He was asking about Fuchs right? And i never said there would be a problem. Read my post again. All i said was that your statement "The 911 suspension wouldn't make it any different for what wheels you can use" is not entirely true as the later 911 hubs change the offset of the wheel mounting surface compared to where it was before with the stock hubs. Something you need to consider when shopping for wheels ... (IMG:style_emoticons/default/bye1.gif) Andy |
PeeGreen 914 |
Aug 25 2008, 10:22 PM
(IMG:style_emoticons/default/blink.gif) Oh, I get what you're saying. Yes, you are right. I didn't say that right. Thanks Andy. (IMG:style_emoticons/default/aktion035.gif)
Eric_Shea |
Aug 26 2008, 12:07 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Ok, so based on your experience, if I install 911 suspension... Will 15x6 or 16x6 fuchs just fit... No Problems? Based on the suspension you mentioned earlier? No problems. While I'm a personal fan of 15's; it's for a weird reason. You might find a better tire selection with the 16's. Again, I'll go back to my original post and say, all this totally depends on what you want to do with your car. A lot of people weighing in with their suspension choices have flares cars with sometimes fairly massive 6's. (IMG:style_emoticons/default/cool_shades.gif) It's important that you make a choice based upon what you will be doing with your car... it's a choice you'll have to live with. The choice for my car is/may be very similar to theirs but, what I would advise others of may be different. (IMG:style_emoticons/default/wink.gif) |
jesiv |
Aug 26 2008, 01:51 AM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Ok, so if I go with 16x6 what is the best tire size to run?
Regards, James |
Aug 26 2008, 12:58 PM
A lot of people weighing in with their suspension choices have flares cars with sometimes fairly massive 6's. (IMG:style_emoticons/default/cool_shades.gif) I'm not a lot of people! (IMG:style_emoticons/default/biggrin.gif) What you're forgetting is that when i bought my 911 frontend 7 years ago, i still had my measly 1.7L engine. I ran that combo for 5 years before i upgraded to a bigger engine ... (IMG:style_emoticons/default/bye1.gif) Andy |
Aug 26 2008, 01:00 PM
Ok, so if I go with 16x6 what is the best tire size to run? 195 x OO where OO depends on what you want. 50 for the cool look and sporty ride, 60 for a more comfortable feeling ... (IMG:style_emoticons/default/bye1.gif) Andy PS: Have you checked out our tire size calculator? http://www.914world.com/specs/tirecalc.php |
jesiv |
Aug 26 2008, 01:39 PM
I was told I will need spacers on the rears. Is this true?
Regards, james |
PeeGreen 914 |
Aug 26 2008, 03:40 PM
I was told I will need spacers on the rears. Is this true? Regards, james Don't know why you would need spacers. Most of the five lug guys that have narrow bodies that I know don't have spacers. The only guys I know that use those have flares. I agree with Andy on the 195s. Personally I would go with th 50s but I like the sportier look and ride. |
Eric_Shea |
Aug 26 2008, 03:55 PM
Todd Enlund |
Aug 26 2008, 03:56 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
50s vs 60s will also affect the effective gear ratio... as will 15 vs 16.
Nominal tire height: 195/50-15 = 22.7" 195/50-16 = 23.7" 195/60-15 = 24.2" 195/60-16 = 25.2" Effective gear ratio difference from the smallest to the largest is over 11%. |
TravisNeff |
Sep 24 2008, 12:33 PM
205x55x16 will be very close to stock rolling diameter.
johnnie5 |
Oct 14 2009, 10:30 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
I voted "Use existing front end replace with 911 strut/hub with 914 Koni Shocks, turbo tie-rods, 914 sway bar" (IMG:style_emoticons/default/agree.gif) As did I. I also went with 911 bolt-on struts/914 inserts (Bilsteins, not Koni's), Lemforder tie rods, rebuilt Shea M calipers, and rebuilt Shea trailing arms w converted 5 lug hubs/914-6 rotors. I also installed new Bilstein shocks and aftermarket coils while I was in there. Sway bar is stock 914 thru-body with aftermarket adjustable drop links. All fairly straightforward to install. As far as wheel/tire size, I chose to go with 15x6 Fuch's and 195 60 Eagle GT's. I was concerned 50's would just be too harsh a ride for me. I want to keep my fillings in my mouth! I am very happy with the outcome. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
ClayPerrine |
Oct 15 2009, 10:31 AM
Life's been good to me so far..... Group: Admin Posts: 15,504 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
RJMII |
Oct 15 2009, 11:26 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
My setup:
I"m running 911 SC struts on the front end, redrilled 4 hubs on the rear (done by Eric) I've got the stock 914 A arms, stock tie rods, etc, just changed out from the ball joint to the top of the shock tower. Stock rear brakes, they work just fine. My car is a street car with 250-300hp depending on how much I turn up the turbo. (see my sig) For the Boxster wheels (in the world of offsets) I was running 16x7 rears with 225's. I was using an 8mm spacer. On the front I was using a 16x6 with a 205, I think? They took a one inch spacer. Now I have 16x7 Fuchs on all four corners, and NO spacers. I'm running 205's. The rear fenders had to be rolled for either setup. I was complimented on how smooth my car rides... but it still handles nicely for the street. |
RJMII |
Oct 15 2009, 11:54 PM
here's how the Boxster rear wheel fit with the 8mm spacer.
TravisNeff |
Oct 16 2009, 12:02 AM
The boxster 16x7 have a 40mm offset
nsr-jamie |
Oct 16 2009, 04:33 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
I have a 911T front end on my car and that is is...I have some new parts coming very soon.
If I were to do it over again, I would probably go with a slightly later suspension with the A or S calipers and some suspension upgrades from Tarret Engineering, than some boxster calipers on front. That would be sweet but a bit of over kill...I guess it depends on what you plan to do with your car. Cheers Jamie |
Lo-Fi Version | Time is now: 4th June 2024 - 07:36 AM |
