Speedo Gauge, How to make connections? |
914helo |
Aug 27 2008, 12:58 AM
Member Group: Members Posts: 235 Joined: 29-September 04 From: Southern Utah Member No.: 2,859 Region Association: None |
I was trying to install my speedometer tonight but couldn't get my hands behind the gauge to hook the speedo and odometer cables. I looked underneath and there is only a little space there as well. Do I need to find some circus midgets? (IMG:style_emoticons/default/confused24.gif) How have the rest of you done this? Thanks
markb |
Aug 27 2008, 01:07 AM
Pull the tach & go thru that hole.
type47 |
Aug 27 2008, 07:32 AM
(IMG:style_emoticons/default/agree.gif) is easier but i have unscrewed the gauge mounting plate (the face with the 3 holes for the gauges) to gain access. you have to have small hands. how did you disconnect the cable in the first place (IMG:style_emoticons/default/biggrin.gif)
914helo |
Aug 27 2008, 08:51 AM
Taking stuff apart is easy, especially when you don't remember the specifics. (IMG:style_emoticons/default/headbang.gif) Removing the tach is a great idea; I'll try that today. Thanks
914helo |
Aug 27 2008, 05:29 PM
Thanks guys. It's alway the obvious I overlook. Pushed out the tach gauge and hooked it right up. (IMG:style_emoticons/default/piratenanner.gif) Thanks
mack914-6 |
Aug 27 2008, 05:35 PM
Member Group: Members Posts: 66 Joined: 29-November 07 From: Toledo, ohio Member No.: 8,388 |
Part gypsy-small hands. (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 12th May 2024 - 04:19 PM |
