914/6 conversion oil line routing |
rfuerst911sc |
Aug 31 2008, 07:31 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
O.K. I'm making progress on my conversion and I'm ready to start installing the oil tank. I have the DW Design aluminum tank and I've cut out the inner fender to accommodate the tank but haven't mounted it yet. I have a few questions on the oil line routing. The forward oil line ( the one under the relay board ) I think I have to cut a hole in the sheet metal to route the line to the engine or thermostat is that right? Has anyone ever used the hole for the engine tray drain lines? I know this is not as direct as a forward hole but it's already drilled and I'm not running a engine tray so the hole isn't being used. And the bottom line from the tank can I see some pics of the routing and possibly the installation of a " tee " for draining the tank? Actually any pics of either oil line would be a great help. I do plan on running a front oil cooler so I will be useing a firewall mounted thermostat, so any pics of that would help also. Thanks guys (IMG:style_emoticons/default/beerchug.gif)
Joe Bob |
Aug 31 2008, 10:15 AM
Are you installing an external remote cooler? Otherwise no need for a thermostat.
If you ARE installing an external remote cooler, the thermostat goes as close to the engine you can.... where are mounting the cooler? Before mounting the tank consider drilling and braising on a bung for a drain plug like the 911 tanks. Otherwise slip the hose over the metal return line off of the cooler and use a clamp. Loosen the clamp slip the hose off and drain. It's a bit messy but it works. A lot of people use an AN fitting there buy that can be a problem area when trying to crack that line to do an oil change. |
rfuerst911sc |
Aug 31 2008, 10:34 AM
Yes I will be installing a front oil cooler. I hope to mount it in front of the tub between the bumper and the valance. I know I'll have to mod the bumper and valance but that can be done with cutoff saw and welder !! I'm useing a brand new DW Design oil tank so I'm not touching that bad boy to install a drain bung. I do want to install a " T ' to drain. Why would that be a problem?
Joe Bob |
Aug 31 2008, 10:37 AM
Yes I will be installing a front oil cooler. I hope to mount it in front of the tub between the bumper and the valance. I know I'll have to mod the bumper and valance but that can be done with cutoff saw and welder !! I'm useing a brand new DW Design oil tank so I'm not touching that bad boy to install a drain bung. I do want to install a " T ' to drain. Why would that be a problem? Not a lot of room, extra fittings making the line not flexible.....drain valves can fail. But it's your car. |
Aug 31 2008, 12:55 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I think I have to cut a hole in the sheet metal to route the line to the engine or thermostat is that right? That hole is already there, even on the /4 cars ... If you look closer, there's a small hole for the drain and a large hole for the oil line. Well, at least on my '70 /4 it's there ... I ran the line straight trough and onto the tank, let me see if i can find a picture ... (IMG:style_emoticons/default/shades.gif) Andy |
Aug 31 2008, 12:59 PM
Ok, in this picture, you can see the blue return line going through the engine shelf and into the bottom of the tank. My car ('70 /4) already had the large hole for the oil line in the engine shelf, no cutting required.
(IMG:style_emoticons/default/bye1.gif) Andy Attached image(s) |
Aug 31 2008, 01:06 PM
And here's the routing from the underside ...
In the picture, you can see the oil thermostat mounted inside the firewall on the right. The green indicates the feed line for the front oil cooler, the blue indicates the return from the front oil cooler going into the oiltank (through the drivers side engine shelf) and the red is the return from the oiltank into the engine. (not hooked up in the pic) ... (IMG:style_emoticons/default/bye1.gif) Andy Attached image(s) |
Aug 31 2008, 01:08 PM
Closeup of the routing into the firewall mounted thermostat ...
Aug 31 2008, 01:12 PM
Aug 31 2008, 01:13 PM
Thermostat sandwiched in the rear firewall:
Aug 31 2008, 01:14 PM
I should probably start a blog! (IMG:style_emoticons/default/laugh.gif)
If you have any questions, fire away! (IMG:style_emoticons/default/beerchug.gif) Andy |
Joe Bob |
Nice pics Andy....I see you have an auto focus now... (IMG:style_emoticons/default/biggrin.gif)
BTW, don't go cheap on the thermostat. I used a MOCAL like in Andy's pic above....to replace the cheap ass one the DAPO used. It failed during start up and sent a big slug of cold oil and assembly lube to the oil cooler. BAM....the whole crankcase vented to the floor of my garage.....instant EXXON Valdez. One difference is that "I" route the lines on the driver side longs, thru the sender well and into the trunk. No biggy, just personal preference. Saves a bit on lines and bends.... |
rfuerst911sc |
Aug 31 2008, 01:48 PM
Ok, in this picture, you can see the blue return line going through the engine shelf and into the bottom of the tank. My car ('70 /4) already had the large hole for the oil line in the engine shelf, no cutting required. (IMG:style_emoticons/default/bye1.gif) Andy Andy your pics are VERY helpful thank you. (IMG:style_emoticons/default/beer.gif) This pic where you have the blue line going thru " an existing hole " is not there on my car as it looks like it was a weld repair in that area. So I guess I'll drill about a 1 1/8 to 1 1/4 hole to allow some rubber channel to be applied for chaffing protection. I plan on running a Mocal thermostat and I hope to run the lines in each rocker under the covers. One supply up one side and one return in the other. Andy how do you like the blue "socketless" oil line vs. conventional ss braided hose and fittings? You must have used it for a reason? |
Aug 31 2008, 02:04 PM
Andy how do you like the blue "socketless" oil line vs. conventional ss braided hose and fittings? You must have used it for a reason? More flexible and much easier to work with. Easier to cut to length and easier to attach to the fittings. (IMG:style_emoticons/default/cheer.gif) Andy |
brp986s |
Aug 31 2008, 05:49 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
Wacky idea maybe, but howabout putting the cooler where the battery is, put a fan under it, and vent thru the grill? I'm speaking of a 3.2 that already has the engine mounted cooler. Alternatively, mount the cooler/fan sideways on the battery tray and arrange air hose thru the existing holes in the engine sheet metal? Howabout that? I really don't like the idea of pumping oil all the way around the car for a street application.
Aug 31 2008, 06:53 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It will likely help a little. It won't likely help much.
A cooler in the engine bay will get engine bay air. That air is hot--often 40F or more than ambient. Coolers work best when they get cool air. The engine bay cooler won't see a very large amount of air flow, even with a fan. Coolers work best when they have a good clean stream of air going through them. So it can work, but it is unlikely to cool super well... Definitely good for reducing the amount of oil lines you need, though! --DD |
ahdoman |
Aug 31 2008, 11:09 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
This is a good thread guys and timely for me as well.
Andy thanks for all the great pics. Rfuerst911sc - If I understand you; are you going to run the send line up the passenger side and the return line down the driver side? I was thinking about doing this as well. Isn't the "send to oil cooler side" already on the passenger side of the engine? And doesn't the return line need to come back to the oil tank in the fender? |
rfuerst911sc |
Sep 1 2008, 08:01 AM
This is a good thread guys and timely for me as well. Andy thanks for all the great pics. Rfuerst911sc - If I understand you; are you going to run the send line up the passenger side and the return line down the driver side? I was thinking about doing this as well. Isn't the "send to oil cooler side" already on the passenger side of the engine? And doesn't the return line need to come back to the oil tank in the fender? I may not have the terminology feed vs. return in the right order but yes one line on either side of the car under the rockers. I found this link which might be helpful. http://www.patrickmotorsports.com/catalogs...EM_LAYOUT_2.pdf |
ahdoman |
Sep 1 2008, 10:25 AM
Ooh, that's good. Thanks for the post. In that drawing; does the "billet" oil filter replace the one on the tank?
rfuerst911sc |
Sep 1 2008, 05:23 PM
Lo-Fi Version | Time is now: 9th May 2024 - 04:41 PM |
