FI assistance, High idle |
watsonrx13 |
Sep 2 2008, 06:15 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, I have finally gotten my second project car running.... The first time since I've owned the car (purchased 2 1/2 years ago)... (IMG:style_emoticons/default/driving.gif)
Anyway, I've done the following to the '74 2.0l engine: New: Spark plugs and wires Distributor cap Points and condensor Vacuum and fuel hoses Intake runner boots Other: Tested and rebuilt fuel injectors and new seals Timed the engine Adjusted the valves I hooked all vacuum hoses, per AA's diagram. When I started it, it ran at 3000 rpm. I disconnected the AAR and plugged the hoses. I've gotten it down to 1500 rpm, but it was 'hunting'. I soaked the AAR valve overnight and washed out the PCV with carb cleaner. I hooked both back up, but it ran at 3000 rpm again. So my questions are: 1. How do I test the AAR valve to verify it's working? 1a. If I remove it permanently, do I just plug the line to the CSV and wrap the electrical wire (the plastic plug is missing)? 2. I've ordered the TB gasket, do I need to remove the runners before I remove the TB/base? 3. After I remove the TB/base and check for pin holes, anything else to check? 4. Any other suggestions? 4a. BTW, I tried spraying carb cleaner around the TB, injectors, runners, but didn't hear any difference in the engine sound. Also, I researched this subject and found Jack's (championgt1) posting, but there was no resolution, at least in that thread... -- Rob |
Lo-Fi Version | Time is now: 16th May 2024 - 09:39 PM |
