V8 guys - Overheating Fuel Pump in the Front Trunk.., Where do you mount it? |
cobra94563 |
Sep 16 2008, 10:16 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
Thanks tony and computors4kids - I'll check the draw and see what where it's at. So if it's at 2amps, should be fine thru the wire I have (i think 16-18).
Yeah, the pump gets so hot, it's hard to believe they were designed to normally operate at that temp. |
tronporsche |
Sep 16 2008, 01:00 PM
Member Group: Members Posts: 281 Joined: 21-August 08 From: California Member No.: 9,447 Region Association: Central California |
How about the fuel filter ? My pump and filter is in the engine bay, and gets hot as well. the fuel filter was rite up against the engine sheet metal, once moved , the problem was less frequent, but as of yesterday, it messed with me again, the car doesn't overheat , neither. I was told maybe I need bigger fuel lines ? It sounds like the fuel pump is starving, I have a Mallory 60.
dakotaewing |
Sep 16 2008, 04:37 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Can one of you guys tell me why you don't use a SBC pump that is mounted on the block?? I thought it was due to the pump not fitting due to the engine mount and bar, but I find it hard to believe that is the case... Am I wrong ??? Thom If your using a electric water pump you can use the stock SBC block mounted mechinacal fuel pump. Otherwise either the waterpump or alternator are in the way. Bob Thanks Bob !!! |
BIGKAT_83 |
Sep 16 2008, 04:49 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I have a Holley red on my SBC car. Mounted in the front for about 10 miles. Its was way too loud mounted there. I moved it to the rear and mounted it in rubber where the stock fuel filter was. You can not hear it run now. Been working great for over 15k miles.
Bob |
stewteral |
Nov 21 2008, 09:39 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
For my 2c, I would agree that you shoud FIRST check out the pump to be sure there is not a problem with shorted windings that could create the heat.
Then, look at mounting the pump back in the engine bay as I did: I ran my fuel line down the right-side chassis box section and mounted the pump low on the right side. It has been working faithfully for 6 years. While I throwing out cheap advice: take the header tank and catch bottle out of the trunk, plumb directly to the engine bay and mount the header tank as high as you can (above the engine) in the rear. I have a small header tank back on the right side of the engine, some 4-5 inches above the water outlet, but still fitting UNDER the engine cover. I filled the car with water and coolant, let the air AUTOMATICALLY extract the air from the system, filled to 1/2 full tank level and have not touched the water in several years! THIS is the right way to use a header tank as there is a 3/8" tube run from the thermostat housing to the top part of the header tank and this is how the AIR separates from the water. It is so easy!! Best of luck, Terry I have an overheating fuel pump in the front trunk. I think it overheats because of the heat coming off the radiator and screws up the pump enough to so I loose fuel pressure down to 1psi. The pump is a new holley red w/a holley regulator. The pump gets so hot you cannot keep you hand on it. I iced it down a bit and my pressure immediately comes back up. I considered the heat could be from the pump, but the wiper motors also get too hot to touch. So where do you mount your pump (if not in the front trunk)? Or what kind of pump do you have (if in the front trunk)? ..or maybe I have to cut more openings..? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:43 AM |
