Grounding Stud, plastic washer?? |
rmital |
Sep 23 2008, 12:09 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
decided to finially dig in and clean up some ground connections last night. Started with the stud that connects to the (-) from the battery. There seems to be a "plastic" washer behind the nut/washer/wire. It also seems to be fixed. Is this original?
I would have figured the wire would have grounded directly to the body not just to the stud connected to the body. any thoughts...pictures...etc.... I'll take a pic of mine tonight |
davep |
Sep 23 2008, 12:18 PM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Not original AFAIK.
It is sometimes a good idea to add a cable from the stud on the engine wall to the fan shroud. This would make a more direct path than through the body, to the transmission ground strap, through the transmission, and through the engine case. The alternator is grounded through the fan shroud, and the starter through the transmission case. Even solid appearing bodies are not the best conductors. |
rmital |
Sep 23 2008, 12:28 PM
davep |
Sep 23 2008, 01:51 PM
In front of the distributor there is an untapped hole suitable for an 8mm bolt. No idea why it is there, but I found it most useful. Get an automotive ground cable (I think about 2 or 4 AWG) of suitable length.
image courtesy of Tom Bliznik & cropped |
rmital |
Sep 23 2008, 02:06 PM
In front of the distributor there is an untapped hole suitable for an 8mm bolt. No idea why it is there, but I found it most useful. Get an automotive ground cable (I think about 2 or 4 AWG) of suitable length. image courtesy of Tom Bliznik & cropped very nice....thanks! |
jk76.914 |
Sep 23 2008, 05:41 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I added two grounds- battery stud to starter bolt (AWG 2, first pic), and alternator mount bolt to the ground stud that is under the relay board (AWG 8, second pic).
Whatever you do, I recommend sandwiching each lug between two internal tooth star washers on the stud or bolt. They cut through corrosion, bite into the steel, and form a realtively gas-tight seal. And they're very very cheap! |
Cap'n Krusty |
Sep 30 2008, 10:08 AM
Am I lost? I was looking for the originality and history page ............... Done properly, the existing ground connections are not only sufficient, but correct and original. Anything else is, well, not. The Cap'n
rmital |
Sep 30 2008, 11:54 AM
Am I lost? I was looking for the originality and history page ..... ...it's kind of like, I went to a fight and a hockey game broke out... (IMG:style_emoticons/default/biggrin.gif) |
Pat Garvey |
Sep 30 2008, 07:59 PM
Lo-Fi Version | Time is now: 20th May 2024 - 11:10 PM |
