Carb Setting Nightmare, Always better to do it yourself?? |
vesnyder |
Sep 27 2008, 06:29 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I have been having issues with adjusting the carbs on my rebuilt 1911 so I thought I would see what a professional could do. This local mechanic specializes in Porsche's and has recently gotten a dyno so I thought I would have him adjust my Webers. The car was running fine but was rich at higher RPM's as confirmed by his dyno and sensors he was using to adjust. I had 28 mm venturis and 115 mains. It ran good but the rich situation gave me concerns particularly on a rebuilt motor. I went to pick it up after he had the car for several days and he said he was having issues. The car was running like crap, backfiring and missing. He said the carbs were adjusted good but it was either the distributor or the valves??? He had put in 195 mains and 34 mm venturis? Upon further inspection he had a 185 in one of the carbs? WTF? On top of that he charged me $320? I am done with so-called experts. This takes the cake!
BTW I am working with Jogn at AirCooled to fix! |
chris914 |
Sep 28 2008, 09:29 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Thanks, The bracket is made of stainless steel to match the linkage made by CSP. I had the bracket CNC from an AutoCAD file I drew up.
http://www2.cip1.com/ProductDetails.asp?Pr...129%2D941%2D400 |
watsonrx13 |
Sep 29 2008, 06:30 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Thanks, The bracket is made of stainless steel to match the linkage made by CSP. I had the bracket CNC from an AutoCAD file I drew up. http://www2.cip1.com/ProductDetails.asp?Pr...129%2D941%2D400 Chris, excellent set up, it's what I've been looking for. (IMG:style_emoticons/default/aktion035.gif) Can you post the dimensions of the cable bracket you made? -- Rob |
chris914 |
Sep 29 2008, 10:42 PM
Thanks, The bracket is made of stainless steel to match the linkage made by CSP. I had the bracket CNC from an AutoCAD file I drew up. http://www2.cip1.com/ProductDetails.asp?Pr...129%2D941%2D400 Chris, excellent set up, it's what I've been looking for. (IMG:style_emoticons/default/aktion035.gif) Can you post the dimensions of the cable bracket you made? -- Rob I can send you the AutoCAD file tomorrow if you want. |
Gint |
Sep 30 2008, 05:29 PM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Chris, excellent set up, it's what I've been looking for. (IMG:style_emoticons/default/aktion035.gif) I can send you the AutoCAD file tomorrow if you want.Can you post the dimensions of the cable bracket you made? -- Rob I also asked Chris if he minded if we made it available on the site. This way folks that want it later could download it from here. Simply refer to this link. http://www.914world.com/image/CSP_Bracket.dxf |
Lo-Fi Version | Time is now: 11th May 2024 - 08:47 AM |
