southernmost914 |
KEY WEST/HAVANA Tunnel Authority ![]() ![]() Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States ![]() ![]() |
Please correct me if I'm wrong, but it appears to me that the ONLY difference between the currently available "racing" SS brake lines and the "DOT" lines is the sticker, certifying that the product so labeled has been tested in accordance with the DOT's specs and procedures. Costs money to do that, and the end user is gonna pick that up. If they can sell 'em to racers, that not-inconsiderable cost can be avoided, and their per-piece profit will be higher. The Cap'n (IMG:style_emoticons/default/agree.gif) Steve |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Both types of hose are TUV certified. I've seen plenty of braided lines sold here in the US that aren't ... (IMG:style_emoticons/default/shades.gif) Andy That's not surprising, since TUV certification isn't required for products sold here in the U.S.. But to rephrase that, braided stainless teflon brake hose have passed TUV tests and are sold in Germany, just as the rubber hose sold there. That of course raises the question of whether they're also seeing these failures in braided lines. QUOTE(Cap'n Krusty @ Oct 2 2008, 09:56 PM) Please correct me if I'm wrong, but it appears to me that the ONLY difference between the currently available "racing" SS brake lines and the "DOT" lines is the sticker, certifying that the product so labeled has been tested in accordance with the DOT's specs and procedures. Costs money to do that, and the end user is gonna pick that up. If they can sell 'em to racers, that not-inconsiderable cost can be avoided, and their per-piece profit will be higher. There is a difference. The DOT 'whip' test described earlier stresses the joint between the hose and the swaged fitting, so hoses that are built to pass the DOT tests have a plastic collar extending a couple of inches up the hose from the fitting. This gives the hose a little support in the whip testing so it doesn't kink the hose where it goes into the swage. Non DOT hoses typically won't have that support collar, so they should certainly be a bit cheaper, and not only because they haven't gone through the expense of testing. If you're paying the same or more for non-DOT "racing" hoses then you're getting... uh... hosed. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
DBCooper |
ztbell |
Newbie ![]() Group: Members Posts: 44 Joined: 8-August 06 From: Jacksonville, Illinois Member No.: 6,619 Region Association: None ![]() |
Both types of hose are TUV certified. I've seen plenty of braided lines sold here in the US that aren't ... (IMG:style_emoticons/default/shades.gif) Andy That's not surprising, since TUV certification isn't required for products sold here in the U.S.. But to rephrase that, braided stainless teflon brake hose have passed TUV tests and are sold in Germany, just as the rubber hose sold there. That of course raises the question of whether they're also seeing these failures in braided lines. QUOTE(Cap'n Krusty @ Oct 2 2008, 09:56 PM) Please correct me if I'm wrong, but it appears to me that the ONLY difference between the currently available "racing" SS brake lines and the "DOT" lines is the sticker, certifying that the product so labeled has been tested in accordance with the DOT's specs and procedures. Costs money to do that, and the end user is gonna pick that up. If they can sell 'em to racers, that not-inconsiderable cost can be avoided, and their per-piece profit will be higher. There is a difference. The DOT 'whip' test described earlier stresses the joint between the hose and the swaged fitting, so hoses that are built to pass the DOT tests have a plastic collar extending a couple of inches up the hose from the fitting. This gives the hose a little support in the whip testing so it doesn't kink the hose where it goes into the swage. Non DOT hoses typically won't have that support collar, so they should certainly be a bit cheaper, and not only because they haven't gone through the expense of testing. If you're paying the same or more for non-DOT "racing" hoses then you're getting... uh... hosed. (IMG:style_emoticons/default/agree.gif) with D B Cooper, The non-DOT version failed on my 914 at the crimp swedge end. now I carry an anchor to deploy as needed... (IMG:style_emoticons/default/smash.gif) Z B |
Mark Henry |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
Mark - you're stifling creativity (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 13th July 2025 - 06:07 PM |
