What do you have for chassis stiffening? |
Justinp71 |
Sep 29 2008, 07:14 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I put some more horsepower in my car, so far I have just autocrossed it on street tires. I have the bolt in roll bar that has the mid bar going to the floor.
Besides that my chassis is stock and I am wondering what I should do for more re-enforcement... so I can comfortably run on slicks. Below is a photo of the roll bar. I don't consider the roll bar to give to much chassis stiffening, but it just might help with cracking the longs. Edit: I mainly just use the car for street and the occasional Autocross or DE Attached image(s) |
Justinp71 |
Oct 3 2008, 04:20 PM
Does the Engman kit reduce body flex? Or just keep the longs from cracking?
You would think it would help flexing, but if the flexing occurs mostly in the diagonal, I don't think the Engman kit keeps the body from diagonally flexing...(IMG:style_emoticons/default/unsure.gif) What do you guys think? |
jcd914 |
Oct 11 2008, 08:56 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Does the Engman kit reduce body flex? Or just keep the longs from cracking? You would think it would help flexing, but if the flexing occurs mostly in the diagonal, I don't think the Engman kit keeps the body from diagonally flexing...(IMG:style_emoticons/default/unsure.gif) What do you guys think? I think anything you do to stiffen the longs will reduce the diagonal flexing ir twisting. I also think the Engman kit will do more than clam shells since it has a piece that ties each side together. That said If you really want to reduce twisting you need to tie upper corners to lower corners, i.e. a cage or a roll bar with diagonal supports. Without a solid roof structure our beloved cars will flex. I plan to build a cage for mine at some point. I even have a tubing bender sitting (never used) with 1 1/2 die and a tubing notcher. Jim |
Lo-Fi Version | Time is now: 19th May 2024 - 11:07 PM |
