fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
Hey,
So - I'm trying to get a bearing off the input shaft of the 901. It's the one that sits behind that nut on the clutch end of the input shaft. I've removed the nut, but I can't get the bearing to break loose and I'm trying to not damage it. Any suggestions? |
914Mike |
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 ![]() |
Hey, So - I'm trying to get a bearing off the input shaft of the 901. It's the one that sits behind that nut on the clutch end of the input shaft. I've removed the nut, but I can't get the bearing to break loose and I'm trying to not damage it. Any suggestions? I just raise the whole shaft and let it fall (IMG:style_emoticons/default/laugh.gif) on a piece of wood a few times till all the little bits scatter to the four corners of the room... (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 11th July 2025 - 12:11 AM |
