| Twise |
Oct 9 2008, 12:43 PM
Member ![]() ![]() Group: Members Posts: 475 Joined: 20-September 06 From: SoCal - Temecula Member No.: 6,881 Region Association: Southern California |
Okay, below is what I got for hardware. Someone gimme the recipe. Thanks...
The long bolts seem to be too long for the b-pillar attach point, but honestly I can't remember.... (IMG:http://i88.photobucket.com/albums/k197/shotouthood/DSC00027.jpg) IE: A+2+Belt+3+1+4 = Bpillar C+6+Belt = Firewall B+5+Belt = Rocker This is what I thought - am I right??? |
| dr914@autoatlanta.com |
Oct 9 2008, 12:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,242 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
a upper bolt at roll bar bolster
b lower bolt at rocker panel c bolt for retractor into firewall 1 spacer for upper in bolster 2 either side of upper seatbelt loop at bolster 3 either side of upper seatbelt loop at bolster 4 rocker to seatbelt 5 upper washer against bolster after spacer 6 used under "c" bolt Okay, below is what I got for hardware. Someone gimme the recipe. Thanks... The long bolts seem to be too long for the b-pillar attach point, but honestly I can't remember.... (IMG:http://i88.photobucket.com/albums/k197/shotouthood/DSC00027.jpg) IE: A+2+Belt+3+1+4 = Bpillar C+6+Belt = Firewall B+5+Belt = Rocker This is what I thought - am I right??? |
Lo-Fi Version | Time is now: 9th September 2026 - 03:39 AM |
