What's the story with the 1.8?, I've read they are less desirable. Why? |
rick 918-S |
Oct 25 2008, 07:39 PM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Something I've been thinking about for a while. As the title states. Are there issues with 1.8's that there isn't with 1.7's and 2.0's? Enlighten me.
Todd Enlund |
Oct 25 2008, 07:43 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Something I've been thinking about for a while. As the title states. Are there issues with 1.8's that there isn't with 1.7's and 2.0's? Enlighten me. I think mostly it's the L-Jet. Otherwise, mechanically, I think the 1.8 is better than the 1.7... better heads, anyhow. |
VaccaRabite |
Oct 25 2008, 07:48 PM
En Garde! Group: Admin Posts: 13,450 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
They are rated at less power then the 1.7 (due to emissions) and have a funky fuel injection system.
Zach |
southernmost914 |
Oct 25 2008, 07:54 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
I don't know but from what I read 1.8 cases tend over heat and loose oil pressure (warp) the metal is differant. 1.8 head or good to modify. (IMG:style_emoticons/default/confused24.gif)
Steve |
type11969 |
Oct 25 2008, 08:01 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I dig the l-jet in my bus, seems pretty reliable. I think djet is a more archaic design and future bosch systems were developed from ljet but I'm not 100% sure.
Vacuum leaks cause bigger problems with ljet I believe. |
southernmost914 |
Oct 25 2008, 08:12 PM
I dig the l-jet in my bus, seems pretty reliable. I think djet is a more archaic design and future bosch systems were developed from ljet but I'm not 100% sure. Vacuum leaks cause bigger problems with ljet I believe. (IMG:style_emoticons/default/agree.gif) YES , If there is a vacume leaks in a L-jet it will run lean and hotter . Over heat,(warp) I think Jake has covered this many times in past threads. Steve |
dw914er |
Oct 25 2008, 08:41 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
They are rated at less power then the 1.7 (due to emissions) and have a funky fuel injection system. Zach yea that. Thats typically why a stock 1.7 is better to have than the 74+ 1.8's. it probably is better overall motor, but the FI and emissions stuff hindered its true potential. |
jim912928 |
Oct 25 2008, 09:08 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Nothing wrong with ljet..just not a lot of experience in the 914 community. drove my 75 for 2 years with the ljet before I yanked it for the 3.2l that is going in it. Ran like a dream. Only thing to watch for is vacuum leaks as the ljet system likes things air-tight!
The 1.8l engines were rated the lowest in HP though..but the heads are desireable! |
Elliot Cannon |
Oct 25 2008, 09:14 PM
I've heard they're more reliable than 928 engines.
(Sorry, I couldn't help it.) |
type47 |
Oct 25 2008, 10:10 PM
Porsche even stated that the L-jet is the more modern EFI system. i think it gets a bad rap because of the 76 hp rating and "everybody" wants more hp. I like my L-jet and it runs very good (knock...). 'course, my D-jet also is running very good too.
zonedoubt |
Oct 25 2008, 10:11 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
The November issue of Excellence actually gives comparable $ values for the 1.8's as for the 1.7's.
jd74914 |
Oct 26 2008, 12:24 AM
My daily driver is a 1.8L with L-Jet. I have 2 D-jet cars and the one L-Jet. I like the L-Jet better. IMHO its a simpler system with less expensive parts that can seriously break (read: MPS). Yes it is less tolerant to vacuum leaks, but this isn't too big a problem. If your car is tuned well there shouldn't be any no matter what system you have.
In driving both, the 2L is faster by far, but the 1.8 makes a great daily driver. Not that D-jet can't do it, but I get around 40mpg driving back and forth to work (highway). Its great. |
7275914911 |
Oct 26 2008, 09:57 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
Hey All,
Maybe I'm biased because all I got is a 75 1.8 running L-Jet(all smog stuff is gone). I can hang with the stock 2.0's that I have been on runs with as long as there are not to many drag strips. I do feel like I have to drive the hell out of it to keep up. But it does keep up!! On the torgue side the 2.0's don't start to pull away till late 3rd gear(around 65 mph). My top end is around 95 on a down hill slope (IMG:style_emoticons/default/biggrin.gif) .... The FI system is very simple. I am a simple man and I have been able to learn the system with ease. I am thinking of modifing it to go on my 2056 later this winter. Somebody talk me out of it (IMG:style_emoticons/default/confused24.gif) and tell me what carbs I should be running! Oh, I got about 30 mpg from Thur to Sun at the RCR. All types of driving over all kinds of gradients. 16x7 rims with 205/55 and 911 front end so I would assume I am a little heavier than stock? JKP |
type47 |
Oct 26 2008, 10:10 AM
Somebody talk me out of it (IMG:style_emoticons/default/confused24.gif) and tell me what carbs I should be running! I'll try to talk you out of carbs. if not L-jet, then consider SDS, Megasquirt or Microsquirt or some modern fuel injection system. |
Bleyseng |
Oct 26 2008, 10:20 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
The knock is that the 1.8's are pretty gutless compared to a 2.0l. Now a 1.8 vs 1.7 is about the same...I like Ljet as its pretty simple and there's hardly any maintanence..
Gint |
Oct 26 2008, 12:11 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Something I've been thinking about for a while. As the title states. Are there issues with 1.8's that there isn't with 1.7's and 2.0's? Enlighten me. Going from 8 cylinders to 4 Rick? (IMG:style_emoticons/default/happy11.gif) Slight (IMG:style_emoticons/default/hijacked.gif) Would a stock L-Jet setup from a 1.8 work OK on a 1.8 based 2056? |
Katmanken |
Oct 26 2008, 12:55 PM
Think back guys...
1973 was the tipping point for fuel emissions..... Before 1973, no emissions issues.... After 1973, there were emission requirements... Since emission control was in it's infancy, most of the fixes involved "detuning" an engine in some way with retarded timing, revised fuel/air maps, air injection, etc. That being said, I like the L-jet. Simple, reliable, and darned near bulletproof. Yes, it is sensitive to neglect (air leaks) and the barndoor sized air flap has a little less response than some systems, but it is reliable. I have an updated system in my 1986 Vanagon (2.1 L) called a Digifant and (except for dirty fuel filter issues and a single worn out switch) it's been 100% reliable since 1986. It looks just like an L-jet on the 914 and has a neat feature where when you take your foot off the gas, the injectors stop flowing until the engine is at 800-1000 rpm. Can you say zero emissions when downshifting? I'm surprised that someone hasn't adapted the Digifant to the 914. Mebbe it's the water cooling thing. Later versions switched from the air flap to a hot wire airflow for improved throttle response. Ken |
Oct 26 2008, 04:26 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
no knock here.
We have all of them and the 1.8 is a great motor... Tune it, change the hoses and drive the hell out of it. Rich |
sean_v8_914 |
Oct 26 2008, 05:19 PM
in 1973 Porsche introduced the 2.0 to replace the six. emissions laws were also changing. compression was lowered as a result. with lower compression came lower HP ratings. in 74 Porsche bumped the displacement of the 1.7 from 90mm to 93mm bores. I speculate this was done to maintain power output simi-level as more emissions equipment was added, further bogging down the motor. In 75 the exhaust was changed to make it burn hotter just to keep pace with further changes in federally regulated emission laws. auto makers of the era were all scrambling to meet the new standards and few were able to comply without great sacrifices to power output and engine longevity. Enter Mr. smog pump 1975...
the 1.8 engine responds dramatically to an increase in compression and back-dating the exhaust system. in its stock form, with all the extra smog junk, they run weaker and hotter than a 1.7. the 1.8 heads have different chambers and bigger valves. an early 1.7 with it's small valves and higher compression makes for a snappier motor off the line but a 1.8 with the same 8.4 compression will keep pulling after the 1.7 has peaked I see far more cracked 1.8 heads than 1.7 heads L-Jet has superior smoothness in daily driver applications throw some 96mm jugs on that L-Jet beast, bump her up to 8.6 to 1 and smile for days |
sean_v8_914 |
Oct 26 2008, 05:20 PM
don't forget to change the 2 o-ring in the L-Jet oil fill cap
Lo-Fi Version | Time is now: 28th May 2024 - 05:46 PM |
