fog lights, where do they attach? |
mattp |
Oct 27 2008, 09:03 PM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
I backdated bumpers and have the "pilot" fog lamps, where do they attach?
I cant figure out how to mount them? thanks |
Oct 27 2008, 09:08 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
on the older cars there is a captured nut in the front wall.
You may need to drill holes and weld on a nut from the back side...not sure. Rich |
SGB |
Oct 27 2008, 09:33 PM
Yep- they bolt right up to the front "wall"/ bulkhead behind the bumper. I think you could through-bolt it (gasp) if you spray a little primer there first.
boxstr |
Oct 27 2008, 10:21 PM
Matt if you do not have the factory captured nuts on the front wall. Let me know and I can supply you with some nuts and allen bolts.
CCLINMIXEDNUTS |
southernmost914 |
Oct 28 2008, 05:38 AM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
This may help.
Steve |
mattp |
Oct 28 2008, 10:09 AM
the pics definelty help, thanks, problem is I do not have that boss or those nuts on my car? My car is a 75, is it possible they actually changed the car stampings?
As for the nuts and bolts, YES, I can use them, I just need to figure out how to get to the backside of where the nut/ bolt would go, it looks like it is below the lights, can I access it from underneath? thanks, matt |
southernmost914 |
Oct 28 2008, 10:47 AM
the pics definelty help, thanks, problem is I do not have that boss or those nuts on my car? My car is a 75, is it possible they actually changed the car stampings? As for the nuts and bolts, YES, I can use them, I just need to figure out how to get to the backside of where the nut/ bolt would go, it looks like it is below the lights, can I access it from underneath? thanks, matt No access from fenderwell or underneath. It is in the void under the headlight bucket. on early models there is access on a late model once your bumper shocks are removed you may be need'in a hole saw. (IMG:style_emoticons/default/sawzall-smiley.gif) Steve |
mattp |
Oct 28 2008, 02:51 PM
do you mean use a hole saw to cut sideways where the bumper shocks used to mount so I could get a nut backt here? ugh!
southernmost914 |
Oct 28 2008, 02:59 PM
do you mean use a hole saw to cut sideways where the bumper shocks used to mount so I could get a nut backt here? ugh! Yhuuup! (IMG:style_emoticons/default/w00t.gif) Or, how about a expandable insert anchor? Steve |
mattp |
Oct 28 2008, 06:47 PM
expandable insert! YES! thanks for the idea!! now I just need to figure out where to drill the hole, anyone able to make any measurements for me??
southernmost914 |
Oct 28 2008, 06:57 PM
Hey,
Mount your bumber and grills with the lights in place behind and mark the mount area with a Sharpy. You may need to shim it with a washer or two , but you got it bro. Add some rubber "o" rings or cut up some rubber for shock asborbing in between (IMG:style_emoticons/default/aktion035.gif) Steve |
blitZ |
Oct 29 2008, 06:47 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
When I backdated my 76 bumpers, there was no mount for my Pilots either. I made my own using a nut plate which I attached with a pop rivet. It works well.
Nut plate |
Lo-Fi Version | Time is now: 11th June 2024 - 04:14 AM |
