Deleted!, Deleted! |
Txgasser |
Nov 18 2008, 08:28 AM
Newbie Group: Members Posts: 22 Joined: 12-November 08 Member No.: 9,743 Region Association: None |
Deleted!
tod914 |
Nov 18 2008, 10:34 AM
The 75/76 style is different than the 74. They 75/76 ignition switch is more difficult to remove along with a few other differences.
Txgasser |
Nov 18 2008, 10:44 AM
Hmmmm, didn't know that thought they were the same and the 76 was different! (IMG:style_emoticons/default/blink.gif)
The 75/76 style is different than the 74. They 75/76 ignition switch is more difficult to remove along with a few other differences. |
tod914 |
Nov 18 2008, 05:12 PM
75/76 is different than the 74. I'm not sure that it matters to you, but I thought I would point that out incase you didnt know.
Txgasser |
Nov 18 2008, 05:44 PM
914Sixer |
Nov 18 2008, 05:52 PM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
TXgasser,
I am over in Boerne. Come over and I will see what I can put together. Give me a call 830-755-4755. Thanks, Mark |
bdstone914 |
Nov 18 2008, 07:48 PM
Thanks! 75/76 is different than the 74. I'm not sure that it matters to you, but I thought I would point that out incase you didnt know. I have the 75 column pulled that you agreed to buy. It is the one with a plastic housing around over the metal ignition assembly. The 74 type has the metal housing that is all one piece. Let me know if that is the type you need. Bruce |
Lo-Fi Version | Time is now: 20th May 2024 - 04:00 AM |
