Pedal Cluster, DAPO strikes again? |
Todd Enlund |
Nov 23 2008, 11:34 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Am I correct in my assumption that this lovely weld bead was added by the DAPO? And that it renders my pedal cluster un-rebuildable?
Eric_Shea |
Nov 23 2008, 11:43 PM
Stick a hacksaw in here and cut it off. It will take about 5 minutes. Then you can get a new shaft and pedal.
I may have a pedal for you but I think my shafts have wallowed holes on the end. I may have a decent pedal assembly for you if you want it... bronze bushings etc. Needs a paint job. |
PeeGreen 914 |
Nov 24 2008, 01:21 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Stick a hacksaw in here and cut it off. It will take about 5 minutes. Then you can get a new shaft and pedal. I may have a pedal for you but I think my shafts have wallowed holes on the end. I may have a decent pedal assembly for you if you want it... bronze bushings etc. Needs a paint job. I have one you can have the next time you're up Todd. |
sixnotfour |
Nov 24 2008, 01:47 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Just grind the weld off. the pin is probably sheered ,the rest is fine.
Lo-Fi Version | Time is now: 12th May 2024 - 03:09 PM |
