Best Suby conversion, What are the best suby engine choices? |
749142 |
Nov 27 2008, 03:26 PM
Member Group: Members Posts: 254 Joined: 8-January 08 From: Bakersfield, Ca Member No.: 8,545 |
as the title states i want to know what the best engine from a suby would be to put into my car. im starting to do research because i plan on a suby conversion but i just dont know what the best engine would be. anybody have any recomended engine suggestions?
westgl |
Nov 28 2008, 12:23 AM
Newbie Group: Members Posts: 41 Joined: 14-November 08 From: Rogue River, OR Member No.: 9,756 Region Association: None |
I have a 2004' EJ254 2.5L with 50K I like this one because it is a later engine, head gasket is better than earlier engine. It is a Single overhead cam engine, less mechanics to deal with. Hydraulic cam, does not need to have valves adjusted. With a good exhaust you should be some where close to the 200hp @ 5600rpm 200ft/lbs tq @ 4000rpm Range, with a 6200rpm Redline That should put you in the 10-11 Lbs/HP Range This is Lotus Elise territory Probably a 13 second quarter mile and some where in a 5 sec 0-60 time should be attainable Westgl |
749142 |
Nov 28 2008, 01:09 AM
thanks for the reply. ive been looking at the EA82T, do you know anything about these? from what ive found out so far they are pretty cheap and easy to come buy, they are a low compression and fairly low boost engine, well CR is 7.7:1. they only produce 110hp at like 5200. but it seems like they can be tuned quite nicely. i just read on a suby forum that they perform a lot better if the heads are ported and polished. they get around 170hp with some mods and 13lbs of boost
so if you could give me any info about these engines maybe good solid bad reports or good reports let me know thanks |
ONTHEGRIND |
Nov 28 2008, 03:14 AM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
thanks for the reply. ive been looking at the EA82T, do you know anything about these? from what ive found out so far they are pretty cheap and easy to come buy, they are a low compression and fairly low boost engine, well CR is 7.7:1. they only produce 110hp at like 5200. but it seems like they can be tuned quite nicely. i just read on a suby forum that they perform a lot better if the heads are ported and polished. they get around 170hp with some mods and 13lbs of boost so if you could give me any info about these engines maybe good solid bad reports or good reports let me know thanks The stock aircooled design can be reliable and be just about equal in power Why not just build a mild turbo type 4 ? |
TonyAKAVW |
Nov 28 2008, 12:25 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I've got a 2001 EJ25 in my car. I love it. More low end torque than the turbo motors, lots more than an Elise....
ConeDodger |
Nov 28 2008, 12:44 PM
Apex killer! Group: Members Posts: 23,580 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Look for your answer on Renegade Hybrids site. They outline all of the Suby engine choices, drawbacks etc...
749142 |
Nov 28 2008, 02:09 PM
well the reason being for switching would be have ac and also to have a more tunable engine, dont get me wrong i love the type fours but i want something qiueter with less maintence involved, such as vavle adjustments.
westgl |
Nov 28 2008, 08:52 PM
There are Subies engines that require valve adjustments,
I have a 2004' SOHC 2.5L EJ254 that requires NO vavle adjustments. (For my 71' 914 new project) I also just bought the 2005' 2.5L it requires Valve Adjustments, Granted it is only every 110k mile intervel that you would do a valve adjustment and this motor only has 30,385 miles so it is barely broken in. EJ2.2T is a good motor, but you would want to change to the latest head gasket before you install. Good Idea to go hangout at a Subaru site to gain some Subie knowledge With any Subie motor that has been pulled out of a car that has not run in several months, and has some mileage on it. You may have to do more or less depending on the miles. before installation change the following New parts needed, 1. Timing belt 2. Thermostat 3. Waterpump 4. oil and filter Drive easy for 1st 300 miles then change oil and filter JMHO Westgl |
749142 |
Nov 28 2008, 09:12 PM
There are Subies engines that require valve adjustments, I have a 2004' SOHC 2.5L EJ254 that requires NO vavle adjustments. (For my 71' 914 new project) I also just bought the 2005' 2.5L it requires Valve Adjustments, Granted it is only every 110k mile intervel that you would do a valve adjustment and this motor only has 30,385 miles so it is barely broken in. EJ2.2T is a good motor, but you would want to change to the latest head gasket before you install. Good Idea to go hangout at a Subaru site to gain some Subie knowledge With any Subie motor that has been pulled out of a car that has not run in several months, and has some mileage on it. You may have to do more or less depending on the miles. before installation change the following New parts needed, 1. Timing belt 2. Thermostat 3. Waterpump 4. oil and filter Drive easy for 1st 300 miles then change oil and filter JMHO Westgl Westgl do you know if they EA82T requires valve adjustment? funny thing you mention joining a subie site becuz i just did before i saw your post |
plymouth37 |
Nov 28 2008, 10:45 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
EJ20, like Conedodger said look at the Renegade site, it really lays out the pros and cons of each engine.
MZM |
Nov 29 2008, 12:57 AM
Newbie Group: Members Posts: 36 Joined: 26-April 07 From: San Diego Member No.: 7,692 |
as the title states i want to know what the best engine from a suby would be to put into my car. im starting to do research because i plan on a suby conversion but i just dont know what the best engine would be. anybody have any recomended engine suggestions? The EA82T is an old Subaru design, no longer in production. The EJ series, 1.8, 2.0, 2.2, and 2.5 liter displacement from 1991 to present came in both normal asperation and turbo models. The turbo models are usually dual overhead cam design, in fact, all are except the early 90's 2.2L Legacy Turbo to my knowledge. This EJ series is the engine that made Subaru a world champanion in rally circuits. Almost all aftermarket parts are for the EJ series, not the EA series. Also, the comments about poor head gaskets in the EJ motors are not part of my experience over 10 years of racing a Subaru with EJ engines. On the other hand, the EA heads are notorious for cracking around the exhaust valve seats. And very hard to locate these days. My advice is to stick to the much better designed and available newer EJ motors. US turbo engines are circa 2001 and up. I hope this is not "to much information" :-). Luck to you and your project. Mike M |
DBCooper |
Nov 29 2008, 08:56 AM
I did the EJ205 WRX turbo motor (2002-2006) and think it's ideal. Not too much torque for the transmission, but all the power you could want. Well, you could want more, you always want more... I'm using the EMS Stinger EMS and the turbo lag I was worried about is no issue at all.
When I was doing research the motor that intrigued me most was the EZ30R. It's the new six, but it's only an inch longer and 70 pounds heavier than the EJ fours. Normally aspirated makes 250 horsepower, which is all I wanted. The buggy guys are turboing them and getting over 600 easy horses, so it's plenty strong. It has both variable valve timing and variable valve lift, so you'd have to run it either with the stock ECU or a Link 4G, which is the only aftermarket unit I've heard of that can control both variables on the valves. I like the idea of a NA six, and with it's firing order and a stock 911 muffler it should even have a Porsche six sound. The only reason I didn't do that motor was a mention by one of the buggy guys that it was difficult to shorten its oil pan. In retrospect, looking at the EJ motor in my car, that wouldn't have been a problem. Downside is that the motor is so new it's hard to find and there aren't any aftermarket performance products for it. I'd certainly go with a newer motor, not one of the old EA's or the SVX sixes. There isn't even that much difference in price. I couldn't be happier with the EJ205, lightweight, about 250 hp in relatively stock form, seems bulletproof, and if that's ever not enough power it's got more hot rod parts available for it than anything this side of a small block chevy. |
749142 |
Nov 29 2008, 03:10 PM
thanks for all the info guys
it really helps so im more informed now and it sounds like the ea is not a very good platform. so ej20 motor it is. when i can afford it. (IMG:style_emoticons/default/dry.gif) but i thought id do my research well before i start on the conversion besides my efforts are still on repairing the damage from that fender bender i just had recently |
pktzygt |
Nov 29 2008, 08:01 PM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
thanks for all the info guys it really helps so im more informed now and it sounds like the ea is not a very good platform. so ej20 motor it is. when i can afford it. (IMG:style_emoticons/default/dry.gif) but i thought id do my research well before i start on the conversion besides my efforts are still on repairing the damage from that fender bender i just had recently Your research will never end. Call renegade and other speak to people who have done the swap. You decided o an EJ? Now decide between the 20ish different versions with a dozen or so ways of doing engine management and hundreds of sources and still keep your pregnant wife from killing you while also doing a build on a trail truck. Is that a run-on sentence. I was horrible at grammar. Welcome to my world. Good luck! Keep me posted. Feel free to PM me and share notes. |
749142 |
Nov 29 2008, 08:29 PM
will do pktzygt
like i said im no where near ready just doing research im thinking ej20tt or ej255 when i get around to it ill post it on my Project Resurection thread |
Zaney |
Nov 30 2008, 01:56 PM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
Deals are out there!
I picked up my 2002 SOHC 2.5L N/A engine (from a TS wagon), 5 speed Trans, stock ECU and wiring harness for $600! Local pickups are the best deals! I am in the same boat too! Pregnant wife making sure that I don't blow the bank! E-bay for new gasket kits and timing belt kits! $300 Good luck in your build! (IMG:style_emoticons/default/beerchug.gif) |
DBCooper |
Nov 30 2008, 07:47 PM
Be careful with the EJ20tt engines. Those are Japanese market, and some US market parts, like junkyard ECU's and intake manifolds, won't interchange. Also that "tt" is shorthand for twin turbo, but it's nomenclature that Subaru themselves never use for their engines. The buggy guys run all out so they can use those sequential turbos, but I understand they're difficult to control in to street applications unless you're using all the original car's harness and accessories.
Renegade would be good for the 914 car side of the equation, but their expertise is really more in the cars and chevy V8's. They do the adapter parts for Subarus but have somebody else do the harnesses and don't do much engine work. Try Outfront Motorsports for the Subaru engine side. They're mostly buggy, but that's still better info for our older cars than the ricer "tuner" companies like Gruppe S, who are usually concerned with OBDII compatability for street cars. Outfront does it all, are very good folks to work with, and will spend time with your questions on the phone. |
pktzygt |
Dec 2 2008, 09:12 AM
Be careful with the EJ20tt engines. Those are Japanese market, and some US market parts, like junkyard ECU's and intake manifolds, won't interchange. Also that "tt" is shorthand for twin turbo, but it's nomenclature that Subaru themselves never use for their engines. The buggy guys run all out so they can use those sequential turbos, but I understand they're difficult to control in to street applications unless you're using all the original car's harness and accessories. Renegade would be good for the 914 car side of the equation, but their expertise is really more in the cars and chevy V8's. They do the adapter parts for Subarus but have somebody else do the harnesses and don't do much engine work. Try Outfront Motorsports for the Subaru engine side. They're mostly buggy, but that's still better info for our older cars than the ricer "tuner" companies like Gruppe S, who are usually concerned with OBDII compatability for street cars. Outfront does it all, are very good folks to work with, and will spend time with your questions on the phone. It took me about .5 seconds to rule out the twin turbo option. If not strictly for the price of replacing 2 turbos that make about the same power as a newer designed single turbo setup. I have sent emails back and froth with the Jeremy at Outfront about engine management and wiring solutions. The EMS stinger is what he reccommends, which seems very reasonable. Also Matt Monson on NASIOC.com seems to be a good lead. You can find a good bit of 914 suby swap info in the Suby Swap forum on NASIOC.com. |
DBCooper |
Dec 2 2008, 09:31 AM
I'm running the EMS Stinger with Outfront's harness on my car, which is the reason I recommend them so highly. Not a thing to complain about. Only good things to stay about Matt, too. Looks like you're on all the right tracks.
Chevota79 |
Dec 2 2008, 09:58 AM
Member Group: Members Posts: 83 Joined: 11-September 07 From: Rocklin, CA Member No.: 8,113 Region Association: None |
Ive have also the twin turbo have problems with the management. I am gonna go with EJ20T also, there are tons of aftermarket parts and I have also found a stroker kit to convert it to a 2.2L, with cams they report around 350 hp, seems exciting. However if i do hit the lotto or get a well paying job after graduation I am probably gonna will an STI motor as I can go to the local auto parts store for parts instead of having to order everything of the net.
Lo-Fi Version | Time is now: 10th May 2024 - 01:10 AM |
