Replacing the Engine Mounts, Is it really necessary? |
ericread |
Nov 29 2008, 07:39 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Well, after reading all the posts that detailed how hard it is to replace the engine mounts, I tackled the work today.
I followed the instructions up to the point where you remove the engine support bar. At that point, the engine bar dropped down with the bottom half of the engine mounts. Yep, both of the engine mounts were broken. The picture shows the four pieces of the engine mounts, where there should only be two. I repaced the mounts, replaced the shifter bar, completed my oil change and presto, the car really shifts and runs much smoother. No shudder in first and second gear. And this greatly reduced running vibration. As for the title of this post.... Yes,it s! About six months ago I replaced the transmission mounts, and here is the picture of the mounts I replaced: So you can see, both the motor mounts and the transmission mounts were completely torn while I used my car as a daily driver. Very lucky for me. The lesson learned is to check your transmission mounts and engine mounts now, and replace them if they look worn. Eric Read |
McMark |
Nov 30 2008, 12:48 AM
Nasty! Good catch.
SGB |
Nov 30 2008, 12:56 AM
I had my car 1000 years befgore I finally did this. Apparently I had even removed and replaced the engine with one bad motor mount. Fortunately, I had replaced the treans mounts during an "engine not dropped" clutch job.
The last step is shifter bushings... |
Lo-Fi Version | Time is now: 11th May 2024 - 07:34 PM |
