Transmission Help !!!, How to remove Pin... |
2-OH! |
Feb 14 2004, 08:08 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Page 76, Item 20...The Haynes manual...
says "remove the stretch bearing bolt (expansion bolt)" but it does not tell me how to get the "Lock Pin" out of the speedo drive, first... It appears to be a roll pin that needs to be drifted out but you can't get to it due to the entire assembly is recessed into the 1st gear Guide Sleeve... Even after the speedo drive is removed, how do you un-torque the "stretch bearing bolt"... All this just to change the 1st gear synchro... Help !!! 2-OH! |
Lo-Fi Version | Time is now: 17th May 2024 - 01:02 AM |
