Door panels, getting down to details! |
914werke |
Dec 9 2008, 09:21 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
The factory put a wax type paper on the panels themselves and glued a
dbl layer plastic sheet over the door frame. Pics anyone? Where do you get the wax paper? (IMG:style_emoticons/default/smile.gif) |
1970 Neun vierzehn |
Dec 9 2008, 09:56 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Rich,
What model year are we asking about? |
914werke |
Dec 9 2008, 10:24 PM
74
Dec 9 2008, 10:31 PM
74 Sorry, can't help with that MY. FWIW, my '70 had no wax paper, only plastic. For reference, here are the grungy, backsides of the '70 OEM door panels. Attached thumbnail(s) |
dlestep |
Dec 9 2008, 11:00 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...a moisture barrier was used to protect the outboard face of the particle board from absorbing trapped moisture between the polyethelene sheet on the door. Any laminate self-adhesive film will give the same protection. Using just the polyethelene sheeting will still allow the base material of the door panel to absorb moisture and deteriorate.
BEMIS manufactures self adhesive laminate films that can be applied to the outboard face (surface facing the interior of the door) and cut to size by hand. Cover the whole surface, from under the top pad to the bottom, and from side to side and wrap over the edges under the panel cover. Moisture comes in between the bottom of the door and the door threshold and can wick through the exposed edges. I live in Florida, in the summer it rains, or I should say, it rains buckets not drops. Don't use Spray adhesives, they attack the old dry conglomerant composition of the original material. (Look at what happened to the back panel base material when exposed to water leaks from a poorly sealed rear window). ...hope this helps |
914runnow |
Jan 22 2009, 07:53 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
The factory put a wax type paper on the panels themselves and glued a dbl layer plastic sheet over the door frame. Pics anyone? Where do you get the wax paper? (IMG:style_emoticons/default/smile.gif) I guess I am gonnah be BAD........ Are you concouring this car? as no judge will know..... And as said below..... Better materials are available.. BUT IF YOU ARE LIKE ME..... I did the Wax Paper...I have a roll that is really close to original...As it is a GARAGE QUEEN...... It will not see much rain... I will send yah some if yah gottah have it... You pay for just the tube and ship cost... Then I won't be the only 914 GeeK...... in the country with fresh wax paper on the door panels!!!! (IMG:style_emoticons/default/aktion035.gif) |
914werke |
Jan 24 2009, 11:47 AM
Its a sickness. (IMG:style_emoticons/default/biggrin.gif)
Thanks for the offer but before I go there where'd you source? |
sixnotfour |
Jan 24 2009, 12:14 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the factory plastic sheet has a second piece seem sealed to it that diverts moisture back into the door.
Pat Garvey |
Jan 24 2009, 07:53 PM
The factory put a wax type paper on the panels themselves and glued a dbl layer plastic sheet over the door frame. Pics anyone? Where do you get the wax paper? (IMG:style_emoticons/default/smile.gif) I guess I am gonnah be BAD........ Are you concouring this car? as no judge will know..... And as said below..... Better materials are available.. BUT IF YOU ARE LIKE ME..... I did the Wax Paper...I have a roll that is really close to original...As it is a GARAGE QUEEN...... It will not see much rain... I will send yah some if yah gottah have it... You pay for just the tube and ship cost... Then I won't be the only 914 GeeK...... in the country with fresh wax paper on the door panels!!!! (IMG:style_emoticons/default/aktion035.gif) Oh baby, you are far from the "only 914 Geek". Well, you won't be if you send me some. Last time I took my door panels off I threw that stuff away, deeming it to be redundant. Now I understand. Gotta have it! Pat |
jonferns |
Jan 25 2009, 06:20 PM
QUOTE I will send yah some if yah gottah have it... You pay for just the tube and ship cost... Then I won't be the only 914 GeeK...... in the country with fresh wax paper on the door panels!!!! Thanks for getting back to me man, its cool that you're offering this. Definetly something cool to have. |
914werke |
Feb 1 2009, 11:56 AM
the factory plastic sheet has a second piece seem sealed to it that diverts moisture back into the door. Jeff (or Anyone) do you still have a door with that dbl layer sheet still intact? Id like to replicated it. Ive already cut a new single layer plastic sheet. (IMG:style_emoticons/default/sad.gif) |
914runnow |
Feb 1 2009, 02:06 PM
Its a sickness. (IMG:style_emoticons/default/biggrin.gif) Thanks for the offer but before I go there where'd you source? Wellllllllllllllllllllllllllllllllll...In my crawl space there was a roll of it there... OR what was left of it.......it is more on the brownish side than the white/brown of the original..But close....I figure it was there from the house being built in 1982... I REALLY tried to find this stuff before I found it.. Folks that I was Crazy??!! (IMG:style_emoticons/default/screwy.gif) BUTYOUUSEWHATCHAGOT I guess.. NOW re the clear plastic my 2 Cents.... I went to Hancock Fabrics and got two mils up on the size.... re the original stuff was wayyyyyyyyyy too thin..PLUS no Judge will ever get his Paws in there!!!...Carefullllllly placed 3M contact spray does great for all of the above.... |
sixnotfour |
Feb 2 2009, 07:38 PM
here you go
the hand model used is very expensive Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:34 PM |
