| Kent |
Dec 20 2008, 11:39 PM
Newbie ![]() Group: Members Posts: 1 Joined: 20-December 08 From: Virginia Member No.: 9,865 Region Association: MidAtlantic Region |
Any helpfull hint on how th get the left /right adjustmet correct on the interior gear shift adjustment? I hve figured out forward and back.
| ChrisFoley |
Dec 21 2008, 12:06 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,035 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
With the trans in neutral, attach a bungee from the shift lever to the passenger side door handle while the adjustment bolt is loose. Rotate the splined shaft to the right as far as it will go, then tighten the bolt.
| Joe Ricard |
Dec 24 2008, 09:02 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Damn I have been screwing around with "one spline at a time" method for all these years.
Now you tell us a secret. |
| jim_hoyland |
Feb 1 2014, 09:42 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,156 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
With the trans in neutral, attach a bungee from the shift lever to the passenger side door handle while the adjustment bolt is loose. Rotate the splined shaft to the right as far as it will go, then tighten the bolt. Would this work for a Rennshifter as we'll ? |
| ChrisFoley |
Feb 2 2014, 08:33 AM
With the trans in neutral, attach a bungee from the shift lever to the passenger side door handle while the adjustment bolt is loose. Rotate the splined shaft to the right as far as it will go, then tighten the bolt. Would this work for a Rennshifter as we'll ? In concept, yes. However, the centering springs probably make it difficult. |
| cpavlenko |
Mar 11 2014, 10:06 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
(IMG:style_emoticons/default/new_shocked.gif) (IMG:style_emoticons/default/new_shocked.gif) (IMG:style_emoticons/default/new_shocked.gif) that is so simple, I'll have to remember this trick. I've always heard this was a nightmare to do it correctly. Thanks 914 world...
| cpavlenko |
| Red72 |
May 18 2015, 05:57 PM
Newbie ![]() Group: Members Posts: 25 Joined: 26-January 15 From: Simcoe, Ontario Member No.: 18,358 Region Association: Canada |
A bit of a ressurection here, but I'm having some 'challenges' with aligning my shifter after a bushing change (tail shifter). Presumably this method is common to tail and side shifters... But my question is if the splined shaft referenced is the forward shaft, connected to the shifter, or the rear shaft to the trans... Logic tells me it's the latter.
Thanks. |
| tomrev |
May 18 2015, 06:44 PM
Member ![]() ![]() Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
A bit of a ressurection here, but I'm having some 'challenges' with aligning my shifter after a bathing change (tail shifter). Presumably this method is common to tail and side shifters... But my question is if the splined shaft referenced is the forward shaft, connected to the shifter, or the rear shaft to the trans... Logic tells me it's the latter. Thanks. It's the splined end, at the shifter lever end,. Does take a bit of work to find the sweet spot. |
| Red72 |
May 21 2015, 12:01 PM
A bit of a ressurection here, but I'm having some 'challenges' with aligning my shifter after a bathing change (tail shifter). Presumably this method is common to tail and side shifters... But my question is if the splined shaft referenced is the forward shaft, connected to the shifter, or the rear shaft to the trans... Logic tells me it's the latter. Thanks. It's the splined end, at the shifter lever end,. Does take a bit of work to find the sweet spot. Excellent, thanks! That will hopefully be my Sunday project. |
| stugray |
May 21 2015, 12:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Another trick I have learned (even if using Racer Chris's method):
Paint some white out across the splines at the adjustment point and then mark both sides of the interface with a mechanical pencil or other accurate marking tool - BEFORE you adjust it. Probably 90% of us will adjust it the wrong way the first 5 times and you want to be able to at least put it back where it was. |
| Red72 |
May 24 2015, 04:58 PM
So I'm now back to a point where I have first through 4th pretty cleanly...but I can't get to 5th. Based on the cutout in the plate within the shifter housing, am I correct to say that 5th is actually slightly further over than 4th? If that's the case I suspect I just need to get a LITTLE more travel to the right and I'll be set.
| Dr Evil |
May 25 2015, 09:05 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Nope. The 4-5, 2-3 throws on a properly adjusted box are equidistant. If you are not getting 5 that is odd. It should be the same amount back as 3 and 1.
| Hine62 |
Jun 8 2015, 01:11 PM
Member ![]() ![]() Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
Where is the adjustment screw? I think R & 1st are way too close to the drivers seat. I'm thinking this will fix it.
hine62 |
| stugray |
Jun 8 2015, 05:06 PM
Where is the adjustment screw? I think R & 1st are way too close to the drivers seat. I'm thinking this will fix it. hine62 On a side shift, the adjustment is made directly behind the shifter. On a tail shift, it is through the access hole right in front of the firewall bushing. You have to loosen the bolt (IIRC 13mm) and rotate the shaft one spline at a time. |
| rgalla9146 |
Jun 8 2015, 06:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,019 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Mark both pieces with a fine tip magic marker
put two or three lines across the splines to reference for depth and a single line in one spline and onto the adjoining piece for rotation |
| db9146 |
Jun 8 2015, 08:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None
So mine is a tailshifter and I just finished replacing all of the bushings in the shifter and the linkage. That took out a lot of slop.
I used this method above to adjust the shifter afterwards and it did improve getting it into first but then noticed that it made it easier to nick reverse when shifting into second, hence my question.... If R and 1st are in the same plane and I have to pull the shifter over to the left against the spring-loaded plate underneath to get 1st, then shouldn't the shift lever move far enough to the right as I shift from 1st to 2nd to be out of the same R-1st plane so that I don't nick reverse? When shifting into 2nd I have released all "left ward" pressure against the spring. What am I missing? Anything else I can adjust? |
| Dave_Darling |
Jun 8 2015, 08:58 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Sounds like you may need to adjust the lever over to the right just a touch more. Or maybe to the left a touch more? But there are many reasons that we tell people to momentarily pause in between gears when shifting a 914; allowing the lever to fall into the correct plane is only one of them.
--DD |
| EdwardBlume |
Jun 9 2015, 07:43 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I use the put it wrong method, and then estimating how much you need to correct it, pull it out, curse, scream, and rip up your hands, and then finally get it in. Results may vary.
For Rennshift, multiply the frustration times 4. |
| ChrisFoley |
Jun 9 2015, 08:48 AM
I use the put it wrong method, and then estimating how much you need to correct it, pull it out, curse, scream, and rip up your hands, and then finally get it in. Results may vary. For Rennshift, multiply the frustration times 4. Problem solved. Replace this: ![]() with this: ![]() ![]() And make accurate adjustments without frustration in a minute. ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 06:17 PM |
