SCCA, Rules |
SCCA, Rules |
Randal |
Jan 12 2009, 05:09 PM
What is the SCCA rule on how high the roll bar must be over the drivers helmet as measured from the top of the roll bar to what?
I think it is like you put a straight edge on the roll bar and extend it forward to the front of the car and you have to have 2" of clearance. Anyone know? |
J P Stein |
Jan 12 2009, 05:45 PM
Read all about it. There are 2 pertinent sections in the rule book which are viewable./downloadable.
http://www.scca.com/contentpage.aspx?content=44 A snippet. 18.4.1. Main and Front Hoops A. Main Hoop: The main hoop (behind the driver) shall be full width of the cockpit. The main hoop shall be as near to the roof as possible on closed automobiles and not less than two (2) inches above the driver’s helmet on open automobiles, with the driver seated normally and restrained by seat belt/shoulder harness. **Low front hoops shall be cowl height, or at a minimum, a straight line drawn from the top of the main hoop to the top of the front hoop shall pass over the driver’s helmet.** B |
bam914 |
Jan 12 2009, 05:46 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
It must be 2" from the top of the main hoop to the top of front hoop.
Randal |
Jan 12 2009, 10:14 PM
DanT |
Jan 12 2009, 10:58 PM
so Randal, where have you been hiding?
haven't heard or seen much of you lately over.................there. |
J P Stein |
Jan 13 2009, 08:51 AM
Randal |
Jan 14 2009, 05:19 PM
OK, from the drivers helmet to the top of the main hoop must be 2". If you draw a line from the top of the main hoop to the front hoop it must pass over the drivers helmet, but it doesn't have to be 2" higher at any point of that potential intersection. Also now I understand the bunny ears on JP's "moving" machine. |
J P Stein |
Jan 14 2009, 06:13 PM
Again, thoes ears would not pass SCCA tech, me thinks. I understand some vintage cars with a similar set up have been grandfathered in by some sanctioning bodies. My ears are not required for AX but are there to keep the car off my head JIC we have a tommy tipover. I wouldn't want to test it out in a 150 mph roll over.
DanT |
Jan 15 2009, 12:38 AM
the silence is deafening (IMG:style_emoticons/default/sad.gif)
Randal |
Jan 15 2009, 01:11 AM
Again, thoes ears would not pass SCCA tech, me thinks. I understand some vintage cars with a similar set up have been grandfathered in by some sanctioning bodies. My ears are not required for AX but are there to keep the car off my head JIC we have a tommy tipover. I wouldn't want to test it out in a 150 mph roll over. "4. Double “ear-type” joints are allowed, provided that they are fully welded at all mating surfaces." So I stopped reading after "ear type" .... and here I thought that I had finally figured out why you had those. Anyway yours are a good idea, just to be safe. Guess if I'm going to pass an SCCA inspection for a hill climb I'll need a higher back hoop. But if I look at Kevin's, it doesn't seem that high. Think we will be doing the initial configuration stuff Saturday. |
grantsfo |
Jan 15 2009, 02:45 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Depends on what you plan to do with SCCA as well. I suspect you could pass local SFR SCCA tech with your car as is. My car passed with the welded on extension. My old car passed Hoopa no problem as well. Is there another SCCA sanctioned hillclimb that you have found?
This post has been edited by grantsfo: Jan 15 2009, 02:49 AM |
Randal |
Jan 15 2009, 12:17 PM
Depends on what you plan to do with SCCA as well. I suspect you could pass local SFR SCCA tech with your car as is. My car passed with the welded on extension. My old car passed Hoopa no problem as well. Is there another SCCA sanctioned hillclimb that you have found? As a base line want to configure the cage to meet SCCA specifications. |
grantsfo |
Jan 16 2009, 09:41 AM
This is the new Solo GCR for roll cages. The 2 " standard appears to be for "specials" Assuming those are the true mod cars? The way I read it is that they reccomend 3" of clearence but any hieght over the head is acceptable?
APPENDIX C - SOLO ROLL BAR STANDARDS A. BASIC DESIGN CONSIDERATIONS 1. The basic purpose of the roll bar is to protect the driver in case the vehicle rolls over. This purpose should not be forgotten. 2. The top of the roll bar shall not be below the top of the driver’s helmet when the driver is in normal driving position, and shall not be more than six inches behind the driver. It is strongly suggested that the roll bar extend at least three inches above the driver’s helmet. In case of two driver cars, both drivers must be within the roll bar height requirement, however only one driver must be within six inches of the roll bar. In a closed car equipped with a roll bar/cage, it must be as close as possible to the interior top of the car. 3. The roll bar must be designed to withstand compression forces resulting from the weight of the car coming down on the roll structure, and to take fore-and-aft loads resulting from the car skidding along the ground on the roll structure. 4. The two vertical members forming the sides of the hoop shall not be less than fifteen inches apart (inside dimension). It is desirable that the roll bar extend the full width of the cockpit to provide maximum bearing area in all soil conditions during rollovers. The roll bar vertical members on formula cars and other single seat cars with a center driver position must be not less than fifteen inches apart, inside dimension, at their attachment points to the uppermost main chassis member. 5. An inspection hole of at least 3/16 inch diameter must be drilled in a non-critical area of a roll bar member to facilitate verification of wall thickness. This should be at least three inches from any weld or bend. 6. It is recommended that steel gusset plates be used at all welds. Gussets should be at least two inches long on each leg and 3/16 inches thick. 7. It is recommended that roll bars be coated only with a light coat of paint. If, however, a roll bar should be chrome-plated, it is recommended that the structure be normalized. 8. Post or tripod types of roll bars are not acceptable. B. MATERIAL After 9-22-85, aluminum is not an acceptable alternate material. Cars using aluminum roll bars or roll cages must file proof with the SD that the structure was approved prior to 9-22-85 as provided in this section. 1. The roll bar hoop and all braces must be of seamless, ERW, or 218 DOM mild steel tubing (SAE 1010, 1020, 1025) or equivalent, or alloy steel tubing (SAE 4130). It is strongly recommended that roll bars not be constructed of ERW due to quality and strength concerns. 2. The size of tubing to be used shall be determined on the basis of the weight and speed potential of the car. The following minimum sizes are required required and are based upon the weight of the car without the driver. a) Over 1500 lbs.-min. of 1-1/” 2 o.d. x .120" wall or 1-3/4" o.d. x .095" wall (IMG:style_emoticons/default/cool.gif) Over 1000 lbs.-min. of 1-1/4" o.d. x .090" wall c) Under 1000 lbs.-min. of 1" o.d. x .060" wall Dimensions are nominal. 0.005” variation in wall thickness is allowed. 3. Each mounting plate shall be at least .080" thick if welded and 3/16" thick if bolted. A minimum of 3 bolts per plate is required for bolted mounting plates. 4. All bolts and nuts shall be SAE Grade 5 or better, 5/16" minimum diameter. C. FABRICATION 1. One continuous length of tubing must be used for the hoop member with smooth continuous bends and no evidence of crimping or wall failure. 2. All welding must be of the highest possible quality with full penetration and will be subjected to very critical inspection. Arc welding, particularly heliarc, should be used wherever possible. D. BRACING 1. It is recommended that braces be of the same size tubing as used for the roll bar itself. 2. All roll bars must be braced in a manner to prevent movement in a fore-and-aft direction with the brace attached within the top one-third of the roll hoop, and at an angle of at least thirty degrees from vertical. It is strongly recommended that two such braces be used, parallel to the sides of the car, and placed at the outer extremities of the roll bar hoop. Such braces should extend to the rear whenever possible. 3. It is suggested that roll bars include a transverse brace from the bottom of the hoop on one side to the top of the hoop on the other side. 219 E. MOUNTING PLATES 1. Roll bars and braces must be attached to the frame of the car wherever possible. Mounting plates may be used for this purpose where desired. 2. In the case of cars with unitized or frameless construction, mounting plates may be used to secure the roll bar structure to the floor of the car. The important consideration is that the load be distributed over as large an area as possible. A backup plate of equal size and thickness must be used on the opposite side of the panel with the plates through-bolted together. F. REMOVABLE ROLL BARS Removable roll bars and braces must be very carefully designed and constructed to be at least as strong as a permanent installation. If one tube fits inside another tube to facilitate removal, the removable portion must bottom on the permanent mounting, and at least two bolts must be used to secure each such joint. The telescope section must be at least eight inches in length. G. INSTALLATION ON CARS OF SPACE FRAME AND FRAMELESS DESIGN 1. It is important that roll bar structures be attached to cars in such a way as to spread the loads over a wide area. It is not sufficient to simply attach the roll bar to a single tube or junction of tubes. The roll bar must be designed in such a way as to be an extension of the frame itself, not simply an attachment to the frame. Considerable care must be used to add as necessary to the frame structure itself in such a way as to properly distribute the loads. It is not true that a roll bar can only be as strong as any single tube in the frame. H. ROLL CAGES It is recommended but not mandatory that all cars utilize a roll cage as defined in Section 18 of the GCR. I. ROLL BAR PADDING Braces and portions of the main hoop subject to contact by the driver’s or passenger’s helmet, as seated normally and restrained by seatbelt and harness, must be padded with a nonresilient material such as Ethafoam ® or Ensolite ® or other similar material with a minimum thickness of one-half inch. |
Lo-Fi Version | Time is now: 6th May 2024 - 05:26 PM |
