Newbie Question, My new pressure gauge is screwed |
kkid |
Jan 15 2009, 05:12 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Please educate me if you know.
This is the back side view of a fuel pressure gauge that I bought today. And I noticed there is a very small screw in the center of the inlet. Don't know what to do with it. Thanks in advance! |
kkid |
Jan 15 2009, 06:04 PM
Anybody?
I am excited to use my first pressure gauge today. Please tell me what to do with the small screw. Should I screw it out or screw it in? (IMG:style_emoticons/default/cheer.gif) |
So.Cal.914 |
Jan 15 2009, 06:10 PM
It is probably how they calibrate it. Don't mess with it. What make and model?
kkid |
Jan 15 2009, 06:22 PM
Thanks Paul,
It's a Summit product. http://store.summitracing.com/partdetail.a...ew=1&N=700+ But if it's left as is, where does the fuel go in from? There is no other hole. God, I feel stupid! (IMG:style_emoticons/default/headbang.gif) |
Aaron Cox |
Jan 15 2009, 06:30 PM
Does it block the hole completely?
The pressure either pushes against that screw (and then the gauge reads that pressure) or it goes around the screw into something else |
kkid |
Jan 15 2009, 07:09 PM
Does it block the hole completely? The pressure either pushes against that screw (and then the gauge reads that pressure) or it goes around the screw into something else Yes, it blocks the hole completely and looks to be tuned only by an eye glass screw driver. I really want to take it out because I really don't know why it's there. Thanks! |
So.Cal.914 |
Jan 15 2009, 07:35 PM
Does it block the hole completely? The pressure either pushes against that screw (and then the gauge reads that pressure) or it goes around the screw into something else Hi Aaron! I thought the same thing. Googled it but ran into a wall. I would not remove it until you contact their tech support. |
southernmost914 |
Jan 15 2009, 07:36 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
It's supposed to be there. It's liquid filled.Just install it and let it be. (IMG:style_emoticons/default/slap.gif)
(IMG:style_emoticons/default/biggrin.gif) Steve |
So.Cal.914 |
Jan 15 2009, 07:41 PM
It's supposed to be there. It's liquid filled.Just install it and let it be. (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/biggrin.gif) Steve He might know that by now. (IMG:style_emoticons/default/av-943.gif) |
kkid |
Jan 15 2009, 09:57 PM
I just installed it and worked fine.
I still wonder how the fuel got into the gauge unit since it looked to be plugged but it is OK. The gauge showed 30 psi at the fuel rail. Thanks everyone! (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 06:22 PM |
