Seatbelt Installation, A Little Help Please |
xperu |
Jan 17 2009, 04:15 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I am re-installing my seatbelts, my problems is the belts have retracted and I can't pull the belt out to remount them. I'm not jerking it, just pulling slowly, but the won't budge. Thanks for the help. Mike
ejm |
Jan 17 2009, 04:51 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Hold the retractor at the same angle it's mounted in the car.
Joe Owensby |
Jan 17 2009, 10:04 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Hold the retractor at the same angle it's mounted in the car. Here is a photo of the pendulum mechanism that actuates the clamp. As mentioned above, if you hold the retractor at an angle, the pendulum thinks it is seeming some "G" forces and wants to clamp. If the correct angle doesn't work, you may have something sticking. JoeO |
xperu |
Jan 18 2009, 07:34 AM
Thanks guys I'll try that, I have 3 sets and all stick and won't unwind, so you are most likely correct. I'll try what you suggested. Thanks Mike
Lo-Fi Version | Time is now: 18th May 2024 - 01:13 PM |
