How to make your CB carb linkage NOT SUCK! |
Aaron Cox |
Jan 18 2009, 07:15 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Ok, I have tried lots of Carb Linkages over the years, and CB performance tends to be revered near the top end with regards to value and performance. There are a few other linkages out there that I like also...
So fast forward 5yrs, and the CB performance linkage has accrued some sucky slop from years of ball in hole wearing. Slop = bad, causing the carbs to not be synched during mid throttle.... Mind you this is the second or third crossbar replacement... even with grease, the hole gets ovaled and sloppy. So, how do we fix this? How can we improve upon their design, BUT not go purchase ANOTHER linkage? Well, simple my friends. A little machining, and parts selection and bobs your uncle! Step 1, Purchase spare set of CB linkage base plates. Proceed to lop off the uprights near flush with the ridge for the air cleaner. Step 2: Bring beer to a buddy, and he will let you use his mill. Or will even mill things for you (IMG:style_emoticons/default/smile.gif) Step 3: Order a bunch of parts from mcmaster.com, Heim Joints, Shoulder Bolts, and Springs (IMG:style_emoticons/default/smile.gif)... Followed by - Find out that mcmaster carr will send you homo pinkish red heim joints and laugh at yourself. Step 4: Drill and Tap Base plates for heim Joints Step 4: Measure 3x, and cut your new extra long cross bar to length, drill and tap ends to fit the shoulder bolts. Step 5: Install stainless springs, Stainless Shoulder bolts, and use blue loctite on all threads. Step 6: Install onto car, note what a great success it is, and drink copious amounts of beer to give yourself a pat on the back. The setup works great. It gets rid of the big extension lever on the offset version of the CB plates.... Gets rid of the worn ball and socket pivot, And self centers like the original linkage did. Hindsight, I would order bearings instead of heim joints next time, and possibly order slightly stiffer springs, or possibly add tension springs on the other side of the heims to increase centering ability. Enjoy (IMG:style_emoticons/default/smile.gif) |
So.Cal.914 |
Jan 18 2009, 07:32 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Aaron Cox |
Jan 18 2009, 07:33 PM
Additional:
The goal was to mimic the TRIAD design, but improve on it also. Ideally, you use the centering spring technology used on CB's design, but improve upon it with heim joints like Triad uses. A marriage of 2 good systems = a better system for less money. 245 for a linkage is too much.... The way i did it, can be made for ~ 60 bucks or so. Triad Linkage (IMG:http://www.triadwestperformance.com/Images/linkage-large.JPG) |
r_towle |
Jan 18 2009, 07:35 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Nice job. I had a setup like that on a race car...it was an old school linkage...
The one thing to watch (at least on a hypo motor) was that the motor itself, therefore the position of the carbs, expands up to a half inch. Rich |
KaptKaos |
Jan 18 2009, 07:40 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Great thread! Who wrote it? :ducks:
Aaron Cox |
Nice job. I had a setup like that on a race car...it was an old school linkage... The one thing to watch (at least on a hypo motor) was that the motor itself, therefore the position of the carbs, expands up to a half inch. Rich Good point- Thats what the springs are there for. I designed upwards of 3/8" expansion into the bar. As the motor grows, the spring force lessens and the bar still stays centered (IMG:style_emoticons/default/smile.gif) |
r_towle |
Jan 18 2009, 07:56 PM
Welcome back from your self imposed exodus.
Are you finally and Engineer? Rich |
scotty b |
Jan 18 2009, 08:30 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
HIGH FIVE
Attached image(s) |
FourBlades |
Jan 18 2009, 08:56 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Classic thread???? (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/piratenanner.gif) John |
Jake Raby |
Jan 18 2009, 09:05 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Cool! One of the things on my task list has been to make a production unit "update kit" to do this with the CB linkage easily. It does make a world of difference.
Aaron Cox |
Jan 18 2009, 10:25 PM
All you need is a few poor college kids who like beer to machine kits for you (IMG:style_emoticons/default/laugh.gif) the hardest part of mass producing a kit would be the custom bar lengths....
Only took a few hours start to finish |
So.Cal.914 |
Jan 18 2009, 10:56 PM
I am going to make one. (IMG:style_emoticons/default/smile.gif) Very cool idea.
craig downs |
Jan 18 2009, 11:14 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Awesome
I miss your project threads, they are always fun to follow along. I hope you have more up your sleeve. |
'73-914kid |
Jan 18 2009, 11:31 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Hmmm....I just bought a bought a complete CB set.
Brand new, and after daily driving use, how long is the linkage going to last? This would be any easy thing for me to make, but I would like to find out how long it will be before I get the fitting ovalling out. But first, I'll need to get my engine so, but everything actually seems pretty strong and tightly clearanced, so I'm not sure what I'll do..... (IMG:style_emoticons/default/unsure.gif) |
Aaron Cox |
Jan 19 2009, 01:02 AM
Hmmm....I just bought a bought a complete CB set. Brand new, and after daily driving use, how long is the linkage going to last? This would be any easy thing for me to make, but I would like to find out how long it will be before I get the fitting ovalling out. But first, I'll need to get my engine so, but everything actually seems pretty strong and tightly clearanced, so I'm not sure what I'll do..... (IMG:style_emoticons/default/unsure.gif) You'll notice some slop after a year or more..... You could always just replace the bar and balls when it happens.... BTW - why does CB performace REAM you on shipping? 12 bucks to ship a cross bar.... and they dont tell you what it costs up front.... (IMG:style_emoticons/default/blink.gif) |
PeeGreen 914 |
Jan 19 2009, 01:07 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Nice work Aaron (IMG:style_emoticons/default/beerchug.gif) It's always fun making things (IMG:style_emoticons/default/piratenanner.gif)
ConeDodger |
Jan 19 2009, 01:10 AM
Apex killer! Group: Members Posts: 23,595 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Great thread but it looks like SirAndy took that second pic with his old camera! (IMG:style_emoticons/default/shades.gif)
ottox914 |
Jan 19 2009, 07:19 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Great thread but it looks like SirAndy took that second pic with his old camera! (IMG:style_emoticons/default/shades.gif) Dd you read step 2 carefully- bring beer to a buddy. It doesn't mention who was to consume the beer. Shame to waste it on the photographer! |
biosurfer1 |
Jan 19 2009, 11:33 AM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
BTW - why does CB performace REAM you on shipping? 12 bucks to ship a cross bar.... and they dont tell you what it costs up front.... (IMG:style_emoticons/default/blink.gif) No kidding Aaron...I bought my fuel pump for them and they charged $35 shipping for a $50 pump. When I called to ask "WTF" she said they made a mistake and she would credit the difference back to me. My mistake was I didn't ask what the credit would be....it was $17 so shipping was still $18 for an item that would have EASILY fit in a $5 flat rate box from USPS. I hate when companies do that! |
rhodyguy |
Jan 20 2009, 10:11 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
springs allowing for side loading suck. much like the stock cb. next time drill, tap and the bar ends using bolts with jam nuts to keep the bar where you want it when the engine is heated up. just like a triad. so...orginal linkage cost, make a throttle cable holder(we've been down this path), eventually have to endure a shitty carb snapping and poping engine, $60+ on improvements, beer, for those of us who are unable to impose upon a friend add what ever the market will bear for machining and you'll almost have a triad. mine is powder coated your's isn't. hi aaron.
Lo-Fi Version | Time is now: 22nd May 2024 - 11:57 AM |
