Guage lighting update for the CSOB, Electro Luminescent illumination for your guages! |
Rotary'14 |
Jan 19 2009, 08:36 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Porsche Gauge illumination upgrade/modification.
For this write up I’ve used a 914 Tachometer, but the method is similar for other Porsche VDO gauges. Pointers appear dim, but this is a short coming of my camera. In real life pointers are easy to see. Tools you will need: Small flat screwdriver Scissors Soldering Iron Wire stripper Crimp tool Parts you will need: 2 wire connectors wire Small diameter heat shrink tubing Clear packaging plastic(saved from trash) Scotch tape solder 5 feet of Electro Luminesent wire 12v inverter for above wire Gauge Dis-assembly: First thing is to open up the gauge. This is done by prying at the bezel with a small screwdriver. Work around ¾ of the circumference of the gauge. It should be possible to remove the front trim bezel holding the lens in place. Beneath the lens is one or two additional bezel trim pieces (depending upon year of gauge). Examine the rear of the gauge and you should notice 3 or 4 small flat head screws. These hold the gauge mechanism in place. CAREFULLY remove the mechanism by loosening the screws, and set the mechanism aside. Attached image(s) |
charliew |
Sep 16 2010, 07:57 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
At night can the gauge lights be turned up brighter than necessary or is the maximum still just barely enough? I know this might be a relative question but I would like to make it brighter than necessary then be able to adjust it down to the desired level. Also I still like the bling of the aftermarket gauges that have changeable colors. Has anyone seen a supplier that has a multicolored strip?
Lo-Fi Version | Time is now: 19th May 2024 - 09:54 PM |
