Starting a 1971 IMSA 914 Restoration, A privateer run 914 with Sebring and Daytona history |
FourBlades |
Jan 21 2009, 08:54 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I am finally starting on the build thread for the IMSA 914. This is a 1971 914-4
that was bought in 1975 or 6 as a used car and turned into an IMSA GTU car. It is a well crafted but not big budget car with a lot of clever touches that helped it to beat a lot of more famous and undoubtedly better financed teams. My wife and I plan to restore the car to racing condition and then enjoy the heck out of it without abusing it any further (its clearly had a hard life). Our priorities are (1) make it safe and legal for current vintage rules (2) keep it original as practical (3) keep it period correct, in that order. We also want to avoid over restoring it too much, but it is easy to understand the temptation to cad plate, power coat, and perfectly repaint everything. I think this last issue will be the biggest, other than going broke or insane first (either one would be a short trip at this point). I plan to post way too many photos, the best quality I can, until people flame me big time to stop. I also expect you, yes YOU!, to help me figure out what to do and give me ideas and comments. I may not always do everything people want, but I will consider all ideas. I'm really just a novice restorer and I know I can't do this without your help. OK, so screw the BS, lets see some pictures. (IMG:style_emoticons/default/aktion035.gif) Competing at Sebring as a 4-cylinder (changed to a six soon after). T.C., who found the car in a barn, passes it on to me (what luck!). I had to turn to a close friend for the financing, but it worked out. Huge ATL 500A fuel cell. The hood just closes over this. TC, URY914, SMG914, and I working on my Explorer flat six conversion. Fiberglass flares and paintwork need a little bit of work. Wife: Are you sure we are buying the right car? Why don't we just buy this one from T.C., it actually has an engine inside the car. (IMG:style_emoticons/default/laugh.gif) I have started to dissassemble the car so it can be soda blasted and I have tons of pictures to post. So what do you all think? John |
FourBlades |
Jan 24 2009, 07:32 PM
Thanks T.C. for the pictures. You know I will be calling you with questions.
Here is the dash area. Notice the old halon fire system. I am a little nervous about disconnecting it. I guess the worst is that it triggers and sprays halon, which I think it pretty inert and non-staining. Weird roll over fuel cut off device which uses ping pong balls. Twin coil ignition system. I'd like to run a twin plug six motor but I guess this is much more expensive than a single plug? Also notice the dzus fastened motor access plate in the firewall. For safety, I will either weld this back up or install some better sealed panel. Wide, fiberglass flares are pretty cracked and beat up. I think I will cut them off while the car is being blasted. There is a lot of rust underneath the fiberglass. I plan to repair the flares and reattach them once the car is expoxy primered. I used to shape and laminate surf boards, so this should not be too hard. The flares were rivetted and glassed originally. I think I will just glass them to eliminate the rust holes created by the rivets. John |
Lo-Fi Version | Time is now: 27th April 2024 - 10:56 PM |
