Starting a 1971 IMSA 914 Restoration, A privateer run 914 with Sebring and Daytona history |
FourBlades |
Jan 21 2009, 08:54 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I am finally starting on the build thread for the IMSA 914. This is a 1971 914-4
that was bought in 1975 or 6 as a used car and turned into an IMSA GTU car. It is a well crafted but not big budget car with a lot of clever touches that helped it to beat a lot of more famous and undoubtedly better financed teams. My wife and I plan to restore the car to racing condition and then enjoy the heck out of it without abusing it any further (its clearly had a hard life). Our priorities are (1) make it safe and legal for current vintage rules (2) keep it original as practical (3) keep it period correct, in that order. We also want to avoid over restoring it too much, but it is easy to understand the temptation to cad plate, power coat, and perfectly repaint everything. I think this last issue will be the biggest, other than going broke or insane first (either one would be a short trip at this point). I plan to post way too many photos, the best quality I can, until people flame me big time to stop. I also expect you, yes YOU!, to help me figure out what to do and give me ideas and comments. I may not always do everything people want, but I will consider all ideas. I'm really just a novice restorer and I know I can't do this without your help. OK, so screw the BS, lets see some pictures. (IMG:style_emoticons/default/aktion035.gif) Competing at Sebring as a 4-cylinder (changed to a six soon after). T.C., who found the car in a barn, passes it on to me (what luck!). I had to turn to a close friend for the financing, but it worked out. Huge ATL 500A fuel cell. The hood just closes over this. TC, URY914, SMG914, and I working on my Explorer flat six conversion. Fiberglass flares and paintwork need a little bit of work. Wife: Are you sure we are buying the right car? Why don't we just buy this one from T.C., it actually has an engine inside the car. (IMG:style_emoticons/default/laugh.gif) I have started to dissassemble the car so it can be soda blasted and I have tons of pictures to post. So what do you all think? John |
FourBlades |
Nov 9 2010, 06:53 PM
Been planning how the oil system will work. This is the oil tank that came with the
car. It looks like it was custom made. I am pretty sure I have seen other oil tanks with the same shape and in the same location as the one in this car. Here is where the tank fits in the car. The tank has internal plates that slope down to a hole in the center. I think the -20 fitting on the side is where oil would enter the tank and drain down into the lower portion. The -20 fitting on the bottom is the return line to the engine. It runs into the passenger area then into the long and out into the engine bay. I am guessing the two fittings on the top are for engine breathers? I am new to /6 engines and am trying to plumb the mysteries of the oil system. I think I can use a 993 oil filter console on the engine to replace the engine mounted oil cooler. I think the oil scavenge pump will feed oil to the front of the car into a thermostat. The thermostat will either feed the front mounted oil cooler and then into the side fitting of the oil tank, or it will send the oil directly into the oil tank. From there its out the bottom of the tank and back to the pressure pump on the engine. I'm thinking of buying a new oil cooler for the car. I have an old RX7 cooler I could have cleaned and tested but /6 engines are too expensive to screw up with a used $50 oil cooler. Any advice or suggestions on the above would be appreciated. John |
Lo-Fi Version | Time is now: 28th April 2024 - 03:35 AM |
