Engine codes |
Engine codes |
JeffBowlsby |
Jan 23 2009, 10:03 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
For your reference: From: http://type2.com/bartnik/enginecodes.htm
Engine Letter Codes -------------------------------------------------------------------------------- This should help you decipher what sort of engine you have in your Porsche. The "Code" column shows the first character or two of the engine code, stamped on the case. Data is supplied for bus cases as well as VW 411/412 cases just in case your Porsche 914 has one of those engines in it (since they are easily interchangeable). Volkswagen Type 1 (Beetle) Code: Year: Engine: 4 1960 1200 5 1961 1200 6 1962 1200 7 1963 1200 8 1964 1200 9 1965 1200 FO 1966 1300 HO/TO 1967 1500 H5 1968-1969 1500 B6 1970 1600 (dual relief, single-port) AE 1971-1972 1600 (dual-port) AH 1973-1974 1600 (8mm head studs w/ case savers) AJ 1975-1979 1600 (fuel-injected) Volkswagen Type 2 (Bus) Code: Year: Engine: Numerals 1961-1963 1200 (see Type 1 listings) O 1964 1500 (no cam bearings) H 1965 1500 HO 1966-1967 1500 (no crossmember holes) B5 1968-1969 1600 (single relief) AE 1971 1600 (with crossmember holes) CB 1972-1973 1700 (dual carb, manual trans) CD 1973 1700 (dual carb, auto trans) AW 1973-1974 1800 (dual carb) AW 1975 1800 (fuel-injected) ED 1975 2000 GD 1976-1979 2000 ('79 has Vanagon heads) GE 1979 2000 (California only, Vanagon heads) CV 1980-1983 2000 (Vanagon -- unique case and heads) Volkswagen Type 3 (Fast/Square/Notch-back) Code: Year: Engine: O 1963-1965 1500 (no cam bearings) TO 1966-1967 1500 UO 1968-1969 1600 (fuel-injected) UO 1970 1600 (dual-relief) U5 1971-1973 1600 (7.7:1 compression) X 1972 1600 (7.3:1 compression) Volkswagen Type 4 (411/412) Code: Year: Engine: W 1971 1700 EA 1972-1974 1700 EB 1973 1700 (California only) EC 1974 1700 Porsche 914 Code: Year: Engine: W 1970-1971 1.7L (8.2:1 compression, D-Jetronic) EA 1972-1973 1.7L (8.2:1 compression, D-Jetronic) EB 1973 1.7L (7.3:1 compression, D-Jetronic, CA) EC 1974-1975 1.8L (7.3:1 compression, L-Jetronic) AN 1.8L (8.6:1 compression, twin Solex Carbs, ROW) GA 1973-1974 2.0L (7.6:1 compression, D-Jetronic, N. America) GB 1973-1975 2.0L (8.0:1 compression, D-Jetronic, ROW) GC 1975-1976 2.0L (7.6:1 compression, D-Jetronic, N. America) VO 1.7L (ROW, magnesium) 1.8L (ROW, magnesium) 2.0L (ROW, magnesium) Replacement Cases (Never supplied in new cars -- only sold over the counter. All are dual-relief with 10mm oil passages). Code: Year: Engine: F1 1300/1600 F2 1300/1600 DO 40-hp part if last digit is "X" D1 Sometimes a 40-hp part AB 1966-1979 1600 AD 1600 AK 1967-1974 1500/1600 AM 1600 AS Sometimes listed as Super Beetle orig. case for '73-on. |
type47 |
Jan 24 2009, 10:37 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
i thought there was a 914 GC code engine for a 76 or 75-76 2L. did i miss something?
Drums66 |
Jan 24 2009, 11:16 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
i thought there was a 914 GC code engine for a 76 or 75-76 2L. did i miss something? (IMG:style_emoticons/default/agree.gif) That's what I have!........Might be USA only?? |
JeffBowlsby |
Jan 24 2009, 11:28 AM
Good catch, see above edits.
Mark Henry |
Jan 24 2009, 01:32 PM
maybe GC should be North America only...we had them in Canada, I have one here somewhere. As well as a CV engine.
Lo-Fi Version | Time is now: 7th May 2024 - 08:05 PM |
