MY SDS EFI Install, Some details of my recent installation of a SDS EFI |
Joe Owensby |
Jan 30 2009, 10:08 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I thought I'd share some details of my recent installation of a SDS fuel injection control unit. First, I would like to thank the admins and contributors on this board for all the information available to help me make the choices I made. I spent a lot of time reviewing the posts about various benefits of the different FI systems, carbs, etc. People such as McMark, MarkHenry, Ottox914, and all-- thanks. The info here was very educational. I am posting this to maybe do my part in sharing experience. A qualifier is due up front. I am no expert in cars, engines, etc. etc. , so I would not want anyone to assume that what I post is correct. It is just what I chose to do. Comments or suggestions are also welcome.
Details: My car is a '73 1.7 that I bought new in 73. I restored the car, and started it up about a year ago. Engine is one of Jakes earlier kits. I highly recommend Jake's products by the way. I had a set of Dellorto 40's on the car. I had to learn how to set the jets, etc., and finally had the car running fairly well. I didn't like the cold nature of the carbs with no choke, and I also wanted a car that I could enjoy the radio in while driving. A lot of the noise was from the carbs. I made a sort of air filter type deal to dampen the noise, but I decided to put a FI system on the car using a stock 2.0 manifold system. The FI system on my car was 35 years old, and almost everything on it was shot. This made the decision to go to an aftermarket FI system a little easier. If I had most of the original components, I would have just tried to get new or at least good components. At least now, all the components should be relatively easy to obtain. So, the details that follow entail replacing pretty much all of the FI system components for the car. After reading about all the available systems out there, I had narrowed it down to a Meagsquirt or the SDS. I chose the SDS because I read a few cases where people screwed up stuff on a Megasquirt and the result was something such as either blowing an engine or letting the magic smoke out of the electronics. I have seen ME screw things up, so I decided to take the more conservative route with the SDS. I am not saying anything against the Mega or Microsquirt systems. However, I can add that the SDS system did turn out to be fairly simple to install and get running- exactly as advertised. I ordered the system on a Friday, and it showed up on my door the following Tuesday, with custom length wires and all. Also, Ross at SDS was extremely helpful in helping me decide what to order, injector sizes, etc. After I got the system, I have asked him two questions about tuning, and the reply was almost instanteous. I couldn't ask for better support than I got from SDS. I'll share details on the system later. FUEL SYSTEM: For fuel pump, I bought a new Bosch fuel pump from a local parts supplier. I bought one of the two port filters listed for a 75 914. This was the best price I could find, and was about half of the cost from other suppliers. I wanted as many new components as I could get to hopefully get better reliability. I bought the front fuel hose/filter kit from AA, as well as their hose kits for the upper and lower engine compartment. These worked well. I had already replaced the fuel lines through the tunnel with SST fuel lines from Chris at Tangerine racing. Great products also. I mounted the pump below the fuel tank, using a removable cover fuel pump mount from a 75 (purchased from a member here). My system had the original type fuel filter before the pump, and I added a metal fuel filter in the engine compartment, mounted where the old MPS was. I used the original 914 steel fuel rails for the injectors, along with a new stock fuel pressure regulator from AA. This came in set to 30PSI, which was the pressure I had intended to use. I purchased an airbox manifold and throttle valve from another member here, Adidas. He only lives about an hour away, so I was able to pick up those parts personally. More details next post. |
Joe Owensby |
Jan 30 2009, 10:32 PM
FUEL INJECTORS:
There is a lot of discussion on this board and others such as thesamba, etc. about what injectors to use. I looked at a lot of options. Several people have used new type Ljet injectors that need slight modifications to fit the original air manifold tubes. These can be found reasonably cheap, but require making a fuel rail or modifying the injectors to accept hoses, and also modifying the injectors to fit the air manifold. Not too big a deal, but something that has to be done. I had almost decided to do this, when I fould new Bosch 0282150007 injectors that were originaly for a VW 411 or 412. These have a flow of 340cc at 3Bar, or about 268cc at 31PSI. This is about 26 pounds/hr at 31PSI, which is a pretty good value to use. These were about $56 each new from Summit. They fit the original manifolds exactly. I wanted to have new injectors as opposed to rebuilt ones, particularly since the ones I had were 36 years old. These are low impedance injectors, so I had to get the resistors installed on the SDS controller. On my engine at high load and high RPM, the injectors max out around a 50% duty cycle, so they are probably a pretty good choice. The recommended maximum duty cycle is 85%, so I am pretty good here. SDS sytem includes wiring as specified. I ordered a system for the Djet injectors, and they sent the system with the resistors pre-wired along with wires to the installed connectors for the Djet. They don't have boots for the injectors, so I ordered boots from AA, and installed these on the SDS wires, along with a heat shrink tubing cover. In the first photo below, you can see the resistor block and the manifold pressure sensor both mounted on the firewall in the engine compartment behind the driver. This seemed like a good place to put them. I tried to route the wires as best as I could to keep them away from spark plug wires. There is also a relay mounted on the side engine compartment where a "6" oil cooler would go. This is for the aux air inlet valve for fast idle when engine is cold. You can also see two "new" red wires coming out of the rear end of the relay board. This is where I picked up the power for the SDS controller and the injectors. I tapped into the relay switched power supply that originally went to the original FI system. This tap is unfused, so i added an external fuse to the controller and the injectors, as can be seen better in the second photo. More to come. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:34 AM |
