Question about replacement of jack receiver tube and pyramid |
Richard Casto |
Feb 10 2009, 08:07 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
The PO had removed the old jack receiver tube and pyramid due to rust. I am going to replace these (not interested in leaving them off). The rust included not just the tube and pyramid, but also the exterior layer of the double wall longitudinal behind the pyramid. I have removed all of the rusted metal, but all that is left is the interior layer which is recessed into the longitudinal. I need to fabricate the exterior layer. The exterior layer also needs to be recessed but I don’t know by how much. If I go too deep the tube will be recessed too much. If I don’t go deep enough then it will not be recessed enough. I know I could just be safe and cut the end of the tube off if it sticks out too much, but I would rather just do it right and recess it the correct amount.
Here is the current situation. You can see the interior layer, but I don’t think (not sure) that the exterior is recessed quite as far back as the interior layer is. I have replacement tubes and pyramids, so I know their dimensions. If someone could measure how far the tube sticks out beyond the flat surface on the top of the pyramid on their car, I can calculate how far to recess my replacement exterior layer. So in the diagram below, I know “A” and “B”. If someone can give me “C”, I can calculate “D”. If you can’t easily measure “C” then a combined “B” + “C” measurement (total height of tube from longitudinal) will work as well. Thanks for the help! |
Joe Bob |
Feb 10 2009, 09:10 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Ever consider NOT using them and filling the rocker panel holes? I have and will again....
Richard Casto |
Feb 10 2009, 10:11 AM
Ever consider NOT using them and filling the rocker panel holes? I have and will again.... I have considered just finishing the job that the PO did and doing a "delete" on the jack point. It would actually be less work. However, this car is not going to see a huge number of road miles and I plan to do proper maintenance such as periodically pulling the rocker panels to ensure it's clean and free of dirt. I also like the idea of restoring it correctly and even having a usable factory style jack point. So they are going back on even though many people are removing theirs. |
Joe Bob |
Feb 10 2009, 10:29 AM
I bet if you posted a poll, the results would show that the use of the jack post is a bit dangerous and most owners go with a floor jack. "I" use the donuts at the four corners of the pan.
Either way, good luck in whatever you decide to do. |
Richard Casto |
Feb 10 2009, 11:47 AM
I bet if you posted a poll, the results would show that the use of the jack post is a bit dangerous and most owners go with a floor jack. "I" use the donuts at the four corners of the pan. Either way, good luck in whatever you decide to do. I would only use the factory jack points for emergancy use/last resort. I am all about using other ways to lift the car such as a floor jack. I think the main reason for removing them is rust prevention and I think that is a non-issue for me personally. You mentioned the donuts, I trust the rear donuts to lift the car and use them, but not the front. I actually am not convinced they were designed for lifting purposes even if they are commonly used for that. The front ones are not supported very well from a structural point of view. Anyone working from home today and have the rockers off their car? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/wink.gif) |
PanelBilly |
Feb 10 2009, 12:04 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Floor jacks from HF are chhep and they have a small one that you can keep in the front trunk. Just my 2cents. I don't like the jack hole or the plastic cover.
rjames |
Feb 10 2009, 12:41 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I'll look at my car when I get home and find out for you. That is, unless someone decides to post the measurement you're looking for beforehand instead of just trying to talk you out of your plans to replace the jack post. (IMG:style_emoticons/default/rolleyes.gif)
jaxdream |
Feb 10 2009, 01:02 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
How about measuring the other side to get a rough idea of what you want ?? Is this possible (IMG:style_emoticons/default/confused24.gif)
Jaxdream |
Richard Casto |
Feb 10 2009, 01:27 PM
I'll look at my car when I get home and find out for you. That is, unless someone decides to post the measurement you're looking for beforehand instead of just trying to talk you out of your plans to replace the jack post. (IMG:style_emoticons/default/rolleyes.gif) Thanks for the help. (IMG:style_emoticons/default/beerchug.gif) Regarding the removal, use of jacks, etc. I figured I would have a few trying to talk me out of it even if I said in my first post I wasn't interested. But I am ok with that. How about measuring the other side to get a rough idea of what you want ?? Is this possible (IMG:style_emoticons/default/confused24.gif) Jaxdream Doh! Why didn't I think of that... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) ...but I can't as the PO removed both jack points, so I have no reference. (IMG:style_emoticons/default/sad.gif) |
IronHillRestorations |
Feb 10 2009, 01:33 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Using algebraic formula to find the value of "C" all you have to do is take the equation: if A=73 and B=30 then C has to be 30 too. Right? .....ahhh bs!
I just measured a good used long I've got on the shelf, and C really is 30. I measured the entire projection from the aft edge of the support pyramid to be 60mm total, and the projection from the pyramid to the end of the jack spur, which is also 30mm. |
Richard Casto |
Feb 10 2009, 02:12 PM
Thanks Perry, that is what I was looking for. That gives an indent of 13mm which is close to what I would have guessed it was.
It's interesting that if you start to measure some of the small details on the car how stuff ends up with really nice even numbers sometimes. 10mm, 15mm, 30mm, 45mm, etc. I can just see the guy at Porsche drawing out the design and using those nice even numbers. |
SirAndy |
Feb 10 2009, 02:29 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I bet if you posted a poll, the results would show that the use of the jack post is a bit dangerous and most owners go with a floor jack. "I" use the donuts at the four corners of the pan. I use the stock jack posts all the time. There's nothing wrong with them as long as the car is free of cancer ... (IMG:style_emoticons/default/shades.gif) Andy PS: The "donuts" were never meant to be used to jack up the car. The ones in the front especially since they're on the underside of the rather thin floor pan and not anywhere near anything structurally sound. |
Joe Bob |
Feb 10 2009, 02:32 PM
I bet if you posted a poll, the results would show that the use of the jack post is a bit dangerous and most owners go with a floor jack. "I" use the donuts at the four corners of the pan. I use the stock jack posts all the time. There's nothing wrong with them as long as the car is free of cancer ... (IMG:style_emoticons/default/shades.gif) Andy I agree, it's the crappy stock jacks that booger them up. I still use my jack posts on my 911 because it's rock solid and I use a plug in jack pad. I just prefer the the donuts on the 914 which the 911 does NOT have. Habit.... |
Lo-Fi Version | Time is now: 19th May 2024 - 12:02 PM |
