OT: L-Jet help for an Italian sports car |
Cevan |
Feb 11 2009, 12:47 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I’m helping a buddy sort out an issue he’s having with a ‘80s L-Jet water-cooled car. This is a car he’s just about done restoring. This is the problem: The car does not idle at a constant speed. Once warmed up, the idle rises from 1000 to 1900 rpms over the course of about 1 ½ to 2 seconds and then drops back down to 1000 rpms in about ½ second. It appears to rev freely.
We have checked all the L-Jet components per his shop manual: AFM, dual relay, TPS, AAR, cold start injector, temp sensors, etc. O2 sensor replaced. We have double checked for vacuum leaks. We have also taken the AAR and cold start injector out of the loop. We’ve confirmed all the injectors are firing and that the cold start injector doesn’t leak. Any ideas? Could it be a defective or malfunctioning dizzy? How does one go about cleaning it, assuming it's sticking inside? Thanks. |
echocanyons |
Feb 11 2009, 01:38 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
What kind of car is it?
Have you checked for vacuum leaks? |
zonedoubt |
Feb 11 2009, 01:54 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
As a search here will reveal: L-jet issues are typically related to vacuum leaks. Start with hoses, gaskets, seals and then move on to the more difficult troubleshooting here: http://manuals.type4.org/ljet/ |
Cevan |
Feb 11 2009, 02:00 PM
It's an X1/9. As I posted above, we've doubled checked for vacuum leaks and found none.
jim_hoyland |
Feb 11 2009, 02:43 PM
Get that VIN ? Group: Members Posts: 9,296 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Can you explain how you checked for Vac leaks ? Having been through this, I found some ways used to check for leaks were not reliable.
Cevan |
Feb 11 2009, 02:52 PM
First, all the vacuum lines were visually inspected. I believe one line that appeared to be inflexible was replaced. Then we used carb cleaner and sprayed it at all the various vacuum line junctions and around the large intake tube (between the AFM and plenum).
Rick_Eberle |
Feb 11 2009, 06:22 PM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
sean_v8_914 |
Feb 11 2009, 09:38 PM
that car has an idle control solenoid that is prone to slow intermittent death. it was also used on the wasserboxer vanagon engines
KaptKaos |
Feb 11 2009, 09:56 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Ask here: http://xwebforums.org/
But please, be courteous when you go there. There's some history between these two forums, so please be on your best. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:43 AM |
