Compression Ratio, Re-"ccing" head |
KevinP |
Feb 13 2009, 04:58 PM
Member Group: Members Posts: 205 Joined: 16-November 04 From: Orlando,FL Member No.: 3,127 |
I had my plug holes relocated and went to the smaller plugs.
Question is- do I really need to re-cc the head? I wouldn't think that the volume would not change any more than a half "cc" at the most. I guess that small amount could make a sizeable difference in the CR calulations. Probley only take me about 15 minutes to set up and do the measuring again. Thoughts anyone.... TIA KP |
Dr Evil |
Feb 13 2009, 05:33 PM
How close are your CR tolerances? If a slight increase of decrease wont mess up your power or ability to use the fuel you wish then I wouldnt bother.
Joe Ricard |
Feb 13 2009, 07:42 PM
What makes you think your cylinder heads were exactly the same before.
Sometimes they pair can be significantly different. |
Feb 13 2009, 11:58 PM
Do it again. A cc or two is enough to make a difference... Make sure they're still the same volume.
--DD |
Jake Raby |
Feb 14 2009, 11:37 AM
What if the heads had a volume differential before??
Never assume anything. Check everything, every time. |
KevinP |
Feb 14 2009, 03:51 PM
The heads were the same before I had the the plug holes relocated. ( Len Hoffman did the work for me). I had cc'd them before the work. Now that I have gone to the smaller plugs of course the over all volume is going to change some. I am going to remeasure again but I was wondering how much of a real difference I should expect to be seeing in The CR ratio due to this small change in volume.
Thanks for everyones thoughts on this matter. I didn't know what to expect to see when I remeasure. KP |
Jake Raby |
Feb 14 2009, 05:38 PM
If Len did the work I am sure he measured chamber volumes after the work was done and balanced them if need be. Len covers all the bases.
Feb 14 2009, 05:45 PM
Lo-Fi Version | Time is now: 16th May 2024 - 04:35 PM |
