Ultra Light Panasport Racing Wheels, Can it be used on my car ? |
levonfarra |
Feb 16 2009, 11:19 PM
Member Group: Members Posts: 173 Joined: 10-February 07 From: Encino, CA Member No.: 7,521 Region Association: None |
Basically, I use my car on weekends (canyon driving, local fun runs, highway cruising, etc.) but I am going to start A/X also. Can the Ultra Light Panasport Racing Wheels be use for these purposes or is it strictly for "racing purposes only". I like the way they look and the fact that it is a bit wider than my 2.0 Fuchs. Any advise or suggestions is greatly appreciated.
Thanks, Levon |
ConeDodger |
Feb 16 2009, 11:52 PM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Basically, I use my car on weekends (canyon driving, local fun runs, highway cruising, etc.) but I am going to start A/X also. Can the Ultra Light Panasport Racing Wheels be use for these purposes or is it strictly for "racing purposes only". I like the way they look and the fact that it is a bit wider than my 2.0 Fuchs. Any advise or suggestions is greatly appreciated. Thanks, Levon People do... Supposedly strong enough... Not intended for potholes and curbs if I understand correctly. I intend to use them on my 240Z Attached thumbnail(s) |
davesprinkle |
Feb 16 2009, 11:55 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Dude, nice Z! How much did the sweet paint set you back?
(Need to lower it, though, if you wanna run with the ricers...) |
ssstikircr |
Feb 17 2009, 12:12 AM
Member Group: Members Posts: 200 Joined: 11-January 09 From: Fair Oaks, Ca Member No.: 9,920 Region Association: Northern California |
I've been running Panasports of n on for about 25yrs. I have run them quite often on the street as daily drivers and I have never bent one yet... knock on wood!! (IMG:style_emoticons/default/aktion035.gif) I love the wheels they look great on almost anything!!!!
ConeDodger |
Feb 17 2009, 12:13 AM
ottox914 |
Feb 17 2009, 07:18 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
As I recall, there are 2 versions of the rim, the "street" and the "for racing purpuses only". I have the for racing purposes only, and use them on the street. I have some stupid light Keizer aluminum rims for auto cross that I'd NEVER want to have to drive on the street. Have had no problems with the 'sports on the street, although I do run a 205 50 tire, run it at 32 psi, and watch out for pot holes and road debris. I think if you had the "racing" rim, and ran some rubber band sidewall, 30 or 40 series sidewall tire, the potential for damages would be much greater. If the "racing purposes" cast into the rim isn't enough of a tip off, the racing rims do not have a ring or groove cast into the center bore for a cap, whereas the street rims will have this groove, so you can class up your rims a bit with a center cap. AND, use stick on weights. The spokes are hollow behind, so if you need weight closer to the outside of the rim, you can do this and not have the wt be seen. The old-school rim weights that hammer on caused slow leaks on all 4 of my wheels- remove the rim weights and replace with stick ons, no more leaks.
First pic is "a study in flat roofs", the 2nd is a close up/wallpaper special. Attached image(s) |
DBCooper |
Feb 17 2009, 07:49 AM
MAN those are good looking wheels! Not enough to make me go back to four lug, but the thought did cross my mind.
Gint |
Feb 17 2009, 08:00 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
They're available in 5 lug.
Edit: ...maybe not in a street version though... |
ConeDodger |
Feb 17 2009, 09:33 AM
As I recall, there are 2 versions of the rim, the "street" and the "for racing purpuses only". I have the for racing purposes only, and use them on the street. I have some stupid light Keizer aluminum rims for auto cross that I'd NEVER want to have to drive on the street. Have had no problems with the 'sports on the street, although I do run a 205 50 tire, run it at 32 psi, and watch out for pot holes and road debris. I think if you had the "racing" rim, and ran some rubber band sidewall, 30 or 40 series sidewall tire, the potential for damages would be much greater. If the "racing purposes" cast into the rim isn't enough of a tip off, the racing rims do not have a ring or groove cast into the center bore for a cap, whereas the street rims will have this groove, so you can class up your rims a bit with a center cap. AND, use stick on weights. The spokes are hollow behind, so if you need weight closer to the outside of the rim, you can do this and not have the wt be seen. The old-school rim weights that hammer on caused slow leaks on all 4 of my wheels- remove the rim weights and replace with stick ons, no more leaks. First pic is "a study in flat roofs", the 2nd is a close up/wallpaper special. Dave, I am going to need some more pictures of that thing if I am going to nominate it for COTM. Too bad you can't get it through your head that you can't turbocharge a TypeIV! (IMG:style_emoticons/default/w00t.gif) |
VaccaRabite |
Feb 17 2009, 10:42 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Basically, I use my car on weekends (canyon driving, local fun runs, highway cruising, etc.) but I am going to start A/X also. Can the Ultra Light Panasport Racing Wheels be use for these purposes or is it strictly for "racing purposes only". I like the way they look and the fact that it is a bit wider than my 2.0 Fuchs. Any advise or suggestions is greatly appreciated. Thanks, Levon Unless I am getting my wheels confused, when they came out with these in the 914 offset, weren't they found to be heavier then the forged 4bolt fuchs? If for looks, go for it. I agree, they look awesome. But if its for performance, I don't know that the slight width increase is counterbalanced by the heavier rotating mass (assuming that they are actually heavier then the Fuchs). Oh, and QUOTE(ssstikircr @ Feb 17 2009) Thats HOT! Zach |
levonfarra |
Feb 17 2009, 01:44 PM
Basically, I use my car on weekends (canyon driving, local fun runs, highway cruising, etc.) but I am going to start A/X also. Can the Ultra Light Panasport Racing Wheels be use for these purposes or is it strictly for "racing purposes only". I like the way they look and the fact that it is a bit wider than my 2.0 Fuchs. Any advise or suggestions is greatly appreciated. Thanks, Levon Unless I am getting my wheels confused, when they came out with these in the 914 offset, weren't they found to be heavier then the forged 4bolt fuchs? If for looks, go for it. I agree, they look awesome. But if its for performance, I don't know that the slight width increase is counterbalanced by the heavier rotating mass (assuming that they are actually heavier then the Fuchs). Oh, and QUOTE(ssstikircr @ Feb 17 2009) Thats HOT! Zach I read that the Ultra light racing ones are 14 lbs. vs. 18 lbs. for the Fuchs. |
Feb 17 2009, 02:15 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
PeeGreen 914 |
Feb 17 2009, 02:40 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
ConeDodger |
Feb 17 2009, 02:41 PM
Andy,
I always assumed that the wheels on the early GT cars were Minilites - not Panasports. In fact, Harvey Weidman was showing me some Superlites or Panasports that he was widening for a customer to mimic the early Minilite wheels... Perhaps I misunderstood and you are just trying to show what 5 lugs in that style would look like... |
Heeltoe914 |
Feb 17 2009, 03:42 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
If you run the rims on the street with a 60 or 70 series tire you will be fine. Thay will look great on your car?
Hope all is well your Brother in laws car is coming along great. |
J P Stein |
Feb 17 2009, 03:51 PM
The old Minilites were light cause they were made of Magnesium...at least the racin' variety. These days they are expensive ...if you can find em' and in pretty rough shape from what I've seen. I saw some 10 X 15s for 1k each.
Stock Fuch (5.5 X 15) are 10-11 lbs, IIRC. 5 lug Fuch 7 X 15 are 11-12 lbs....depending on whose bathroom scale you're using. From what I remember reading, ultra light Panasports...... aren't. |
Feb 17 2009, 04:36 PM
Perhaps I misunderstood and you are just trying to show what 5 lugs in that style would look like... That was indeed the intent ... (IMG:style_emoticons/default/shades.gif) Andy |
ottox914 |
Feb 17 2009, 05:50 PM
The old Minilites were light cause they were made of Magnesium...at least the racin' variety. These days they are expensive ...if you can find em' and in pretty rough shape from what I've seen. I saw some 10 X 15s for 1k each. Stock Fuch (5.5 X 15) are 10-11 lbs, IIRC. 5 lug Fuch 7 X 15 are 11-12 lbs....depending on whose bathroom scale you're using. From what I remember reading, ultra light Panasports...... aren't. As I recall, the factory 4 bolt Fuchs, 15 x 5.5 were silly light- no matter WHOSE bathroom scale I was using. I'd have no reason to believe the factory 5 bolt 15 x 7's wouldn't be similarly light. However, the factory 15 x 7- 4 bolts have been SO hard to find lately, so I had to settle for the light but not ultra light Panasports in a 15 x 7. (IMG:style_emoticons/default/biggrin.gif) I really like the narrow body look, and since I have "invested" the Keizers and 'sports, its likely to stay that way. If I were to go with flairs and 5 bolt, I'd be hunting down some factory 15 x 7's for sure. Not the "classic" look of the 'sports, but a very classic look of their own. |
levonfarra |
Feb 17 2009, 06:55 PM
A quick photoshop job.
scotty b |
Feb 17 2009, 07:12 PM
They look good on a 356 too
Lo-Fi Version | Time is now: 16th May 2024 - 07:36 AM |
