Rear Rim Offset for GT Flared Car, What fits the best? |
jmill |
Feb 17 2009, 03:13 PM
I just bought 7's for the front and I'm looking around for rims for the rear. What 8" 5 lug Fuch offset fits the rear of GT flared cars the best? The prices of the 9" rims has me running scared.
dr914@autoatlanta.com |
Feb 17 2009, 03:26 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
PeeGreen 914 |
Feb 17 2009, 03:28 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
On my car I have the 15x8's with a spacer that is close to an inch to fill out the wells perfectly. I too am running scared of the price of 9s but they are sooooo sexy.
My 8's have 8Jx15 and 911.361.020.42 on the back with the 42 in a big box. then under that there is AS10.62 I really don't know what numbers are important. I can run these without spacers but they flare looks empty unless you use the spacer. |
Racer |
Feb 17 2009, 04:17 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Hmm the standard 8x16 911 fuch had an offset in the 10-15mm range. I would figure the 8x15 would have the same offset range.
They will have a 911.xx.xx part number. Tough part will be the limited tire selections... 225-50, 225-45 and maybe still a 245-50-15 were what I remember from a few years ago. Maybe its changed? |
jmill |
Feb 17 2009, 04:37 PM
Forgot to add that the fronts I have are 16's. I'll need a 8x16's for the rear. Do all the 911 rims have the same offset?
jasons |
Feb 17 2009, 04:54 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
(IMG:style_emoticons/default/hijacked.gif)
Where can you even get tires for 15x9's? The widest, readily available 15 inch tire I have seen is a 225. At least in street tires. |
jmill |
Feb 17 2009, 06:13 PM
Hoosier makes some. Purely track tires. But like I said I'm looking at 16's. My main concern is the difference between the 911 and 951 offset.
degreeoff |
Feb 17 2009, 06:30 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
here is mine with 9eleben wheels, look fine to me (IMG:style_emoticons/default/biggrin.gif) Now all I need to do is rid myself of some 7"ers on the front aquire two more 8x15's through whatever means nessasary to give myself 2 sets of 8x15's for my track tires and then get a nice set of 16's for the street........tires are way easier to find!
elmonte |
Feb 17 2009, 06:41 PM
Member Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
elmonte |
Feb 17 2009, 06:52 PM
I run 15x8 on all 4 corners w/225-50 for canyon carving and 16x7 on all corners w/225-55 for the freeways. Here's a picture of the 16's
jaminM3 |
Feb 17 2009, 07:47 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
That is awesome! (IMG:style_emoticons/default/piratenanner.gif) I have never seen it put on a chart in such an easy to understand format. NICE! |
jmill |
Feb 17 2009, 08:07 PM
That chart is fantastic!!!!!. That sucker needs to get nailed somewhere here.
Joe Ricard |
Feb 17 2009, 08:26 PM
I'm fitting 15x10's under the rear of my fiberglass GT flares.
race rubber section width of 11 inches. That is the absolute max and I got little rub marks to prove it. Backspace is 5 3/4" |
zig-n-zag |
Feb 17 2009, 09:11 PM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
911 7 x 16 = 4-3/4" backspacing
951 7 x 16 = 4-3/4" backspacing 911 8 x 16 = 4-15/16" backspacing 951 8 x 16 = 5-1/4" backspacing Those are the measurements I physically took (WHEW!) |
LarryR |
Feb 17 2009, 10:21 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
Hoosier makes some. Purely track tires. But like I said I'm looking at 16's. My main concern is the difference between the 911 and 951 offset. You can run 951 8's all the way around and they fill up the flares nicely. Then you get wheels that you can actually rotate your tires with too. |
gothspeed |
Feb 17 2009, 11:05 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Forgot to add that the fronts I have are 16's. I'll need a 8x16's for the rear. Do all the 911 rims have the same offset? This forum is great! I was just wondering what wheels I will need for my future gt flares. I too am considering 16" fuchs ..... though was contemplating 8" front and 9" (930 wheel) back OR 7" front and 8" (944T wheel) back This will give the 'illusion' of the same wheel width from the outside but gain a tad on the inside of the rear wheels (IMG:style_emoticons/default/smile.gif). I run 15x8 on all 4 corners w/225-50 for canyon carving and 16x7 on all corners w/225-55 for the freeways. Here's a picture of the 16's |
charliew |
Feb 20 2009, 09:14 AM
I think I read that the tire will rub on the inner fender before it rubs the trailing arm. Is that because of the bushings flexing or the inner fender is the closest point? I believe I read the back of the inner fender well is the spot.
Lo-Fi Version | Time is now: 17th May 2024 - 06:22 PM |
