917 style shifter knob for your Rennshifter, You are going to love my balls! |
VaccaRabite |
Feb 23 2009, 09:26 AM
Okay, I am offering 917 style knobs as a 914 World Exclusive to see if there is demand. At the moment, I can only offer knobs for Rennshifters.
My price is $50 + $6 shipping. I'll put as many knobs in the box as you want for 1 shipping fee (so long as I have them made and can fit them and some padding in the box to protect them). PM me for details on how to pay. Paypal is preferred. All the knobs are hand carved of Maple and Mahogany. Knobs may vary slightly in size and color. All knobs will be ~45mm in diameter and weigh between 35 and 40 grams. Each ball is finished with at least 2 coats of tung oil. Tung oil gives a deeper color and luster to the wood, without the plastic look and feel that polyurethane would give. As the ball is used, oils from the hand will further shine the knob, giving it a very pleasing patina. Each knob is made to screw directly on to a Rennshift shifter, no glue or crush rings required. My first knob used a 1/16th inch spacer to fit it flush on the shifter. This has been engineered out of my balls. These knobs are cooler then aluminum in the summer, and warmer in the winter. They also weigh less then the aluminum knobs that I have been able to weigh, by as much as 1/3 less. (IMG:http://farm4.static.flickr.com/3098/3271133109_551a3643bc.jpg) If there is demand for these (ie, if I sell the 3 I have on hand) I'll make more. At the moment, I do not have a solution for stock shifters that use a crush ring. For the $75 ball on the market now it is suggested to glue it on to the shifter, as the ring will break up the wood. This is not an acceptable solution to me, and I see no reason to step into this market unless I can offer a substantial improvement over the existing design. I'll post better pictures when I finally get my camera back from the shop. Until then, the above pic is the first unfinished ball that is now on my car. Zach |
PeeGreen 914 |
Feb 23 2009, 10:45 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/drooley.gif) Very nice work (IMG:style_emoticons/default/aktion035.gif)
70Sixter |
Feb 23 2009, 02:50 PM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
I like them also.
Why couldn't just drill out your balls (ouch) to stock diameter and use the crush ring from Porsche. If the wood won't handle the stress you could drill it more and line the hole with copper tubing or pipe. Maybe even plastic. |
Dr Evil |
Feb 23 2009, 03:00 PM
I like them also. Why couldn't just drill out your balls (ouch) to stock diameter and use the crush ring from Porsche. If the wood won't handle the stress you could drill it more and line the hole with copper tubing or pipe. Maybe even plastic. (IMG:style_emoticons/default/agree.gif) |
VaccaRabite |
Feb 23 2009, 04:34 PM
I already have a plan in mind, using aluminum tube.. But I don't know the OD of the crush ring, so I don't know what the ID of the tube needs to be.
If anyone can give me either the OD of the crush ring or the ID of a stock shifter knob, I could tool up to make them easy. The Rennshift knobs are easy though, as once I have the shaft in place I can chuck that into my drill press for shaping. And I already have the materials for them. Once I sell the 2 remaining knobs I have, I may look into making them for stock applications. But for the moment, I don't have enough information, and very little free time to find it. Zach |
PeeGreen 914 |
Mar 3 2009, 08:00 PM
(IMG:style_emoticons/default/piratenanner.gif) Just got mine in the mail. The pictures don't do it justice. A very nice work of art Zach. I am happy to have one of these. Now to get my car back on the road so I can feel how this feels in my hand (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif)
charliew |
Apr 3 2009, 04:46 PM
Zach the id of a stock knob is .650+- .004 The crush ring is similar to the sleeve in the steering column shaft but much smaller that I have but it doesn't work very good. When I have a running car I will probably either use duct tape or silicon to hold the knob on.
VaccaRabite |
Apr 4 2009, 08:06 PM
Awesome. I bought some 3/4 inch aluminum tube with a .652 ID. I will use this to re-enforce where the crush ring goes.
I'll hopefully have a bunch of these at Hershey. I think I have about 10 ready to cut out, but just have not had time to make them. I have 2 of the Rennshifter style balls left, by the way! Zach |
70Sixter |
Apr 7 2009, 02:07 PM
Zach the id of a stock knob is .650+- .004 The crush ring is similar to the sleeve in the steering column shaft but much smaller that I have but it doesn't work very good. When I have a running car I will probably either use duct tape or silicon to hold the knob on. I have never had a crush ring problem. Maybe yours was already crushed. New one have been fine for me. I have had to use a rubber padded open ended wrench and a hammer to get them off. On my old 912 the screw-on shift knob was never adequately replaced by after market products. They usually used a set screw that worked loose over time. |
VaccaRabite |
Apr 27 2009, 01:10 PM
I only have one of these left, and don't know when I will have any time to make more.
Let me know if you want it. Zach |
PeeGreen 914 |
Apr 27 2009, 02:50 PM
and they sure are nice. I just got mine mounted on te shaft. I'll be taking pictures soon. Awesome work Zach.
BKLA |
Apr 30 2009, 12:06 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
Really nice and a lot cooler (warmer) than the solid aluminum one.
I like the "old school" look. Here's a really *bad* phone camera shot Very Nice Zach!!!!! |
VaccaRabite |
Jun 9 2009, 07:56 AM
Bump!
I still have one left. May be the last one ever, unless I find some spare time to make more. Zach |
Zimms |
Jun 10 2009, 04:16 AM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
PM Sent
VaccaRabite |
Jun 18 2009, 02:11 PM
Last one I have for the time being is sold.
JazonJJordan |
Jun 27 2009, 12:37 AM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
Okay, I am offering 917 style knobs as a 914 World Exclusive to see if there is demand. At the moment, I can only offer knobs for Rennshifters. My price is $50 + $6 shipping. I'll put as many knobs in the box as you want for 1 shipping fee (so long as I have them made and can fit them and some padding in the box to protect them). PM me for details on how to pay. Paypal is preferred. All the knobs are hand carved of Maple and Mahogany. Knobs may vary slightly in size and color. All knobs will be ~45mm in diameter and weigh between 35 and 40 grams. Each ball is finished with at least 2 coats of tung oil. Tung oil gives a deeper color and luster to the wood, without the plastic look and feel that polyurethane would give. As the ball is used, oils from the hand will further shine the knob, giving it a very pleasing patina. Each knob is made to screw directly on to a Rennshift shifter, no glue or crush rings required. My first knob used a 1/16th inch spacer to fit it flush on the shifter. This has been engineered out of my balls. These knobs are cooler then aluminum in the summer, and warmer in the winter. They also weigh less then the aluminum knobs that I have been able to weigh, by as much as 1/3 less. (IMG:http://farm4.static.flickr.com/3098/3271133109_551a3643bc.jpg) If there is demand for these (ie, if I sell the 3 I have on hand) I'll make more. At the moment, I do not have a solution for stock shifters that use a crush ring. For the $75 ball on the market now it is suggested to glue it on to the shifter, as the ring will break up the wood. This is not an acceptable solution to me, and I see no reason to step into this market unless I can offer a substantial improvement over the existing design. I'll post better pictures when I finally get my camera back from the shop. Until then, the above pic is the first unfinished ball that is now on my car. Zach (IMG:style_emoticons/default/welder.gif) Nice wood Zach, tough looking balls~ I have OEM shifter but great work! |
Lo-Fi Version | Time is now: 10th May 2024 - 01:36 PM |
