SOT: About Bolt Ratings, Grade 8 is not appropriate |
McMark |
Mar 4 2009, 12:52 PM
Hey guys, I was just reminded about a common misconception that I felt compelled to try and help dispel. It has to do with how fasteners are 'graded'. Often times you will see people talking about high stress joints and people insist on recommending 'Grade 8' bolts. But the fact of the matter is that SAE and Metric bolts are rated differently.
From a thread on TheSamba: QUOTE ISO (Metric) Grade 8.8 is the rough equivalent of SAE (US) Grade 5 ISO (Metric) Grade 10.9 is slightly stronger (in both yield and tensile strength) than SAE (US) Grade 8 It's quite common for people to go to the hardware store looking for 'Grade 8' metric bolts, see the 8.8 stamping on the head of the bolt, and think they've found the correct part. But the truth is, for high stress joints that require better quality fasteners, our cars need 10.9 bolts, not 'Grade 8'. |
VaccaRabite |
Mar 4 2009, 01:13 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You know, I had no idea... Thanks for this post. I need to staple it into my brain.
Zach |
6freak |
Mar 4 2009, 01:33 PM
In my world S.A.E grade 5`s have 3 hash marks and grade 8s have 6....Grade 5`s will stretch before they break giving you a warning ....grade 8`s are brital and just break with no warning ......OSHA requires grade 5`s in all load bearing parts of an overhead crane system ...A325 on the bolt head is also considered a grade 5
Solo914 |
Mar 4 2009, 01:41 PM
Member Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None |
In my world S.A.E grade 5`s have 3 hash marks and grade 8s have 6....Grade 5`s will stretch before they break giving you a warning ....grade 8`s are brital and just break with no warning ......OSHA requires grade 5`s in all load bearing parts of an overhead crane system ...A325 on the bolt head is also considered a grade 5 (IMG:style_emoticons/default/agree.gif) , I was writing the same exact thing. I can't remember though, is it better to have Grade 5 or Grade 8 in shear applications? I distictly remember a cheat sheet for telling you what grade to use in certain applications(shear, tensile, constant load etc) Kyle good reading. Pretty much negates what I wrote above. http://www.rockcrawler.com/techreports/fasteners/index.asp and http://www.boltdepot.com/fastener-informat...rade-Chart.aspx |
6freak |
Mar 4 2009, 01:56 PM
I myself like 5`s for they can tell you things ...8s are just too brital ..but it really depends on the application..constant loads i would say 8s shear i would take the 5`s ..JMO
6freak |
Mar 4 2009, 02:08 PM
Just read the rock crawler.com page ...wow .....I learn something new everyday ..but it comes down to this!! what type of application and what do you want to do with it
Trav012000 |
Mar 4 2009, 02:23 PM
Member Group: Members Posts: 59 Joined: 23-September 08 From: Indiana, USA Member No.: 9,583 Region Association: Upper MidWest |
Our Chinese Tempering oven here at the factory uses a 4.4 bolt. Needless to say, we've had to replace quite a few bolts. (IMG:style_emoticons/default/tongue.gif)
davep |
Mar 4 2009, 05:12 PM
You also have to consider the size of the bolt. You cannot say I'll replace an ISO 10.9 with a SAE grade 5 because they will stretch and not break. If you do, you may have to go from a M6 bolt to a 1/2" bolt for example.
It is far better to get the exact replacement bolt since some engineer agonized over the selection of it in the first place. |
MrKona |
Mar 4 2009, 07:49 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
I'm confused. (IMG:style_emoticons/default/confused24.gif)
I always replace metric with metric. Does SAE hardware "fit" in place of metric hardware? |
6freak |
Mar 4 2009, 09:21 PM
You also have to consider the size of the bolt. You cannot say I'll replace an ISO 10.9 with a SAE grade 5 because they will stretch and not break. If you do, you may have to go from a M6 bolt to a 1/2" bolt for example. It is far better to get the exact replacement bolt since some engineer agonized over the selection of it in the first place. I agree 100% ..Im basically say`n for bolt on stuff !such as winch bumpers and things like that . the none engineered none load bearing parts ..In some cases SAE will work in place of Metrics... The threads are differant and of course the head size ...but Im with Davep and yourself if you can put origional bolts and nuts in place do so |
plymouth37 |
Mar 4 2009, 10:53 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
I'm confused. (IMG:style_emoticons/default/confused24.gif) I always replace metric with metric. Does SAE hardware "fit" in place of metric hardware? Usually not (IMG:style_emoticons/default/biggrin.gif) . I was however planning on replacing all of the standard bolts used on my conversion kit with metric bolts. I thought it was stupid to have standard bolts mounting a japanese engine into a german car but what do I know, Renegade only stocked standard so that is what I had to use (IMG:style_emoticons/default/screwy.gif) Anyway thanks for the info, I was wondering about that. |
McMark |
Mar 4 2009, 11:05 PM
I'm not suggesting that SAE and Metric are interchangeable. They're not. But people say, "Go get yourself some M12 grade 8 bolts" which is impossible. They really mean "Go get yourself some M12 grade 10.9 bolts."
Lo-Fi Version | Time is now: 17th May 2024 - 05:17 PM |
