FS: 2.0 Cylinder cover tin (pair) |
MrKona |
Mar 10 2009, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
For sale is a set of 2.0 cylinder head tin.
Looks like the driver's side tin was repainted at some point. It has a small crack at a mounting hole, toward the front of the car, I've tried capturing it in the pictures. No cracks around the spark plug area. Looks like someone welded an underside nut at one of the spark plug wire clip holes. (IMG:style_emoticons/default/confused24.gif) The passenger side tin has surface rust, but no cracks that I can find. It could use a bead blasting and repaint. Otherwise, it appears to be in good shape. I also have a few other tin pieces if there is something else you're looking for (no heat exchanger cover tin though). $40 + shipping. Paypal preferred. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 02:31 AM |
